« 1 (2)
Re: torque
From Mandurah WA
water injection...wouldnt it mix witht he fuel and make it less potent ?
Posted on: 2003/8/21 17:30
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: torque
You still have just as much fuel and air (practically speaking), so the answer is no. Instead, the water cools the a/f mixture, so you advance the timing. The effect is similar to intercooling, but it's done internally (it cools the mixtuer in the cylinder during combustion).
There have a been a few factory turbo cars that used water injection, but I did not realize you could use it to positive effect on a normally aspirated engine.
Posted on: 2003/8/22 19:43
Re: torque
From Hobart, Tas. Australia
Surprisingly water injection also helps clean the internals of the engine - but it should be shut off well and truly before the engine is switched off otherwise you can be left with water sitting in the bores.
A friend of mine runs a 2500PI Triumph in Targa and he uses a water atomiser from an agricultural supplies company and sprays the water into the injection plenum. He says it helps calm the motor down when they are running it hard at high revs for long periods.
I've planned to do it for ages but not got around to it. My friends have a button half way down the gearstick and just turn it on during races etc when they think they need it.
It has other benefits too - but I'll have to go check my notes.
Posted on: 2003/8/28 8:46
SPITSUN - A12GX powered Triumph Spitfire
View my spitfire on Triumphowners.com
Re: torque
A big advantage of water injection is that you can run a far higher comp. ratio, so power is going to go UP.
When I was an engineering stude, I recall reading a paper about some guy in UK who modified a 250cc BSA bike engine so that about 25% of the charge going thro it was water. I ran very nicely on about 14 or 15:1 CR and gave about 28 BHP.---this is in the 1930's remember
Posted on: 2003/8/29 2:51
« 1 (2)
