Lights flicker in dash when driving
Quite a regular
From Long beach,Southern California
Hey guys,I have a 73 Datsun 1200 coupe, lights in the dash flicker when I drive at night, not all the time though, maybe ground issue? If anyone has any ideas, I greatly appreciate the help. thanx
Posted on: 2009/5/29 20:14
Re: Lights flicker in dash when driving
It could be a loose hot wire.
But usually it is a loose earth/ground wire. The instrument cluster ground via a screw to the metal dash. If it is loose it could cause flickering.
Posted on: 2009/5/30 6:46
From pooraka,,adelaide
do they flicker much?
mine do heaps if i turn my stereo up
Posted on: 2009/5/30 15:03
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Quite a regular
it would be a short in your positive shorting to ground i would think.
although it could also be loose earth as said before.
and andy you would have a short aswell. probably just some insulation of the + and - wires. just when you turn stereo up it vibrates and the wires would touch
Posted on: 2009/5/31 1:29
bloody oath
yer i kno i gotta bad earthy cause sometimes my car wont start cause of it
Posted on: 2009/5/31 1:50
vanette-a15 turb
260c- daily
1000 4dr- a15
garage 910
From illawarra, nsw australia
im not trying to go agaisnt what anyone else has said
but andys problem is most probably because the draw from his stereo is too much when he turns it up
this happened to me until i ran an amplifier which has a MOSFET system or something and draws power equally instead of in bursts like your stereo would if there is a loud bass line
you can also combat this by installing a more powerful battery or what they call a capacitor which draws a more steady current and feads it to your stereo
Posted on: 2009/5/31 4:42
Quite a regular
I'll look into some more, thanx for all help, i'll keep you guys posted, thanx again
Posted on: 2009/5/31 20:12
Here are the two grounding screws.
Posted on: 2009/5/31 22:00
nah it still does it with mine and im runnin a good amp and a large battery
but all good i dont wanna hijack this thread
goodluck mazdat
Posted on: 2009/5/31 23:02
vanette-a15 turb
260c- daily
1000 4dr- a15
garage 910
Quite a regular
Hey andy-roo, I've had cars with sound equip. in them and the same thing happens, light dim to the sound of the music, my problem is that it seems like the cluster looses power and comes back, do you have a capacitor in your system?, I've heard that its helps with your problem, and no worries, you're not hijacking the thread.
Posted on: 2009/6/1 4:52
