brakes and turbo??
From dominican republic
hi i have a 1200 ute and i wanted to know how can i install rear disc brakes if its possible, can anyone help me with that?? and the other thing is can i use a turbine of a diesel engine in my a12?? cause i have a toyota diesel turbo in house and i dont know much of these things i would like to use it in my ute
Posted on: 2009/6/6 2:22
Re: Rear Disc Brakes
Yes, PitRoad sells them for 1200 Pickup.
Or you can do it yourself. You'll have to design and fabricate some parts. Read up Rear Disk Brakes.
Posted on: 2009/6/6 3:18
Re: Rear Disc Brakes?
Posted on: 2009/6/6 3:21
Re: brakes and turbo??
thanks man and what about the other thing can i use a toyota diesel turbo for my a12 engine??
Posted on: 2009/6/6 3:49
From hervey bay queensland
they are some nice looking brakes , does anyone in australia do a kit like this for the standard ute diff??
Posted on: 2009/6/6 4:44
classic not plastic
Re: Can I use diesel turbo??
Sure can. Might be a little big. Most people use the diesel turbo off a 1.0 or 1.3 liter.
Posted on: 2009/6/6 5:15
its that truth that i need to change pistons when installing turbo?? i dont konw much about these things
Posted on: 2009/6/6 14:40
Nothing you hear is "true" when it comes to turbos. It all depends, almost everything works depending on how you do it.
You don't need:
* new pistons
* an intercooler
* fuel injection
* a special carb
Those are good for optimizations. But can turbo without it.
Read up about it in the Datsun1200.com Tech wiki: Turbo.
Posted on: 2009/6/6 19:07
thats´s great thanks and what about blow off and wastegate do i need that?? i just have the turbine and the intercooler and mi a12 is stock is a 1992 model
Posted on: 2009/6/11 18:37
You don't need any blow-off valve or a wastegate...it all depends on your setup.
Posted on: 2009/6/12 4:22
