Browsing this Thread:
1 Anonymous Users
Re: clutch wont grab, new conversion |
Registered Users Contentmaster Usermaster
Maybe someone has one from a B210 5-speed (63 series) and can measure the length it should be?
Posted on: 2009/6/4 7:12
From Christchurch NZ
I think the thrust bearing has more to do with which flywheel you have. I'll take a look at my 63a, (Which is out ATM) and see which one it has
Posted on: 2009/6/4 10:09
Forced Induction! Because everyone knows you don't bring a knife to a gunfight!
Yes, there are two throwout bearing sleeves depending flywheel for the 56 and 60 series transmission. Actually I think it is not the flywheel, it is whether or not you using the block plate which comes with A14 engines.
Yet the 63 series is different...
Posted on: 2009/6/5 2:41
From Vancouver BC Canada
Im not sure where the fly wheel came from, it might have even been from a f10 a14. the plate I used between the engine and the tranny looked to be a shy 1/8" and was the complete one, unlike the automatic plate which was thin and only a have plate.
Im still unclear if i should be lengthening the master rod or loosening it, if it is lengthening it, would shims help?
Posted on: 2009/6/5 3:19
Quote: If at first you don't succeed, lower your standards. Keith (Mac-Datty)
You should be tightning the rod, to make is shorter. You need play at the pedal.
Datsun 1200 calls for 1 inch play. B210 with 5speed is about 1/8 play.
Posted on: 2009/6/5 3:43
OK, I cut off ± 3/4" from the rod. I have ± 1/8" free play now.
when the clutch pedal is up, there is now a ticka ticka ticka sound. this goes away with a slight pressure on the pedal.
Posted on: 2009/6/6 23:38
Do you have the correct 63a clutch slave cylinder? It is self adjusting.
Look at it, if you can adjust it then put 1/8" free play there too.
Posted on: 2009/6/7 0:19
The slave is self adjusting, I wonder if I should bleed the clutch since I removed the rod from the cylinder. some fluid came out when i pulled the rod out.
Posted on: 2009/6/7 0:58
Car was written off, I was rear ended by a municipal front end loader... No longer an issue.
Posted on: 2014/7/7 2:54
Keep that gearbox! Or better yet, give it to me! Sorry for your loss mate.
Posted on: 2014/7/7 7:56
