RPM Malfunction ?
From Sri Lanka
Hi Guys
I have after market tachometer, it was not working so i removed the back cover of it , i have got wires mainly one is RED other one is Black, and also i see burned wire from inside the tachometer, so i realized that is that the reason it does not work ? what would be that wire to where it is connected ? , i tried to connect Red to the Iginition negative and black to ground earth then that worked but when i start the car it goes to the 6000 rpm and stay and when i increase gas it is increasing, but i don't think so that is the correct way it is connected
what do u think guys, i want to make my older tacho to work or just throw it away and buy one , if it works in wain i am buying a new one
thanks
regards
sumith
3
Posted on: 2009/6/8 5:03
Re: RPM Malfunction ?
Red is probably battery +, black is earth, and the burned wire was coil -.
Posted on: 2009/6/8 5:44
From Sri Lanka
hI ddgonzal
i also thought so i fixed red to 12 V and black to ground then suddenly tacho went to maximum level , so i got scared to fix it and removed back , do u have any idea where the broken wire should be connected into the tacho ?
thanks
regards
sumith
Posted on: 2009/6/8 6:01
From Sri Lanka
Hi ddgonzal
It is clear , it is Coil Negative (green colored wire),it has been broken from the scratch i cant find where it is coming from ?
thanks
regards
sumith
jpg  Tachwiring.jpg (38.59 KB)
10994_4a2c9d7c85632.jpg 611X292 px
Posted on: 2009/6/8 6:11
I do not know. I've had no success fixing broken tachometers
Posted on: 2009/6/8 6:40
