driveline questions
From gold coast
out tonite taking dato for run and ute wouldnt stop spining the rears, now its very cold out, so i warmed em up with a little foot on. my first question is it spun only one wheel? -its got a r31 lsd diff so should it be doing this? second question is how can i beef up the gear box? i am looking for more power down the track (338rwhp at the moment)...any help would be great
Posted on: 2009/6/11 13:00
Re: driveline questions
From Geelong, Vic
borgwarner LSDs are #OOPS#...so yes spinning one wheel for them is normal, mini spool will solve that problem
Posted on: 2009/6/11 13:41
From pooraka,,adelaide
strait cut gears?? would that give more power or just improve the gear changes?
expensive but would sound good too
Posted on: 2009/6/12 2:47
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Posted on: 2009/6/12 2:48
vanette-a15 turb
260c- daily
1000 4dr- a15
garage 910
How much torque does your engine put out? Gearbox ratings, like diff, are in torque. Your CB71C standard should be good for about 250NM. Is it giving you trouble at the moment?
Posted on: 2009/6/12 10:07
From Geelong, Vic
stock box should handle it, but after that you'd probably be looking at grafting a CA bell housing onto an R33 or Z32 box, like what they do for SRs that have lots of power
Posted on: 2009/6/12 10:31
