manifold question
Quite a regular
can anyone tell me do ineed to weld up the head where the water goes from head to manifold? or can you seal it some other way.
Posted on: 2009/6/12 12:22
Re: manifold question
No need to weld it. The manifold matches so just bolt it up. If you have a 'dry' manifold, but the head is the 'wet' type, the most common solution is to drill and tap the head holes, and fit allen-wrench plugs.
Posted on: 2009/6/12 18:42
Quite a regular
yes want to use dry manifold, head is off a14 but the hole is about inch and 1/4 long by 1/4 inch bit to big to drill n tap?
Posted on: 2009/6/13 1:44
Quite a regular
my mistake looking at manifold not head
Posted on: 2009/6/13 15:41
From Melbourne, Oz
I ream'd the holes and made some pess fit alloy pins and taped them in and peen'd the ends alittle, and when I machined the whole surface you couldent even see whare they where. and I hav a gx head that has be'n drill'd and taped if you do that just remember to put some tefflon tape or silican or something?
Posted on: 2009/6/14 2:01
"I hav achieved wood"
