« 1 (2)
Re: fitting 15 inch trx rims
From Geelong, Vic
you will be able to get 15mm bolt on spacers, but it would be cheaper to change struts id reakon
trx rims are 15x5.5
Posted on: 2009/6/2 4:46
Quite a regular
From sunshine coast QLD
changing struts is probably the more legal way from what i've been told, also a good way to get bigger brakes. what struts are easist to fit and more likely available?
Posted on: 2009/6/2 11:20
From Geelong, Vic
its pretty much the same amount of effort to fit any of the bigger struts, stanza and sunny ones dont require the spring perch to be changed but with them you will end up having #OOPS# all suspention travel
200b/240k, 180b and bluebird struts are probably the best option
Posted on: 2009/6/2 11:33
Not too shy to talk
From Northern Rivers, NSW
anyone know of a a cheap place to pick up spacers?
Posted on: 2009/6/16 17:39
ASK ABOUT IT! Datsun 1200 sedan for sale, worked A14, professional respray, NO rust
From pooraka,,adelaide
sprints
Posted on: 2009/6/16 21:37
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
« 1 (2)
