#1 5 speed question
Weekend1000 Posted on: 2009/6/25 0:53
Was the 60 series 5 speed ever made with 5th gear being 1:1
(not overdrive)?
#2 Re: 5 speed question
Dundee1000 Posted on: 2009/6/25 1:38
No..
#3 Re: 5 speed question
ddgonzal Posted on: 2009/6/25 4:13
Over the years, several club members reported having seen or owned a non-overdrive 60-series 5-speed. But so far, no one has posted a picture or any documentation about it. I guess it could be true. But it seems unlikely.
So no...
#4 Re: 5 speed question
Weekend1000 Posted on: 2009/6/25 9:13
Thanks Guys
#5 Re: 5 speed question
revhead001 Posted on: 2009/6/25 9:18
They can be made to be 1:1. It is easy enough to check.
#6 Re: 5 speed question
edp Posted on: 2009/6/26 6:30
I could be wrong but it seems like the one I just rebuilt (FS5W60A 5 spd. from a 81 210) was 1 to 1 in 5th gear. I put a sharpie mark on both the input & output shafts at the same place & counted the # of turns of the input vs. the output shaft & I'd swear that 5th gear was 1 to 1, if its not exactly its really close.
#7 Re: 5 speed question
ddgonzal Posted on: 2009/6/26 7:12
yes it's really close. It's 0.821 fifth.
When you rebuilt it, did you notice there was no fourth gear (just the shafts lock together, gears freewheel-- which is 1:1). But there is a fifth gear.
#8 Re: 5 speed question
edp Posted on: 2009/6/26 18:04
My method wasn't very scientific so that ratio seemed like a 1 to 1... pic's of trans.
this shows the 5th / rev. gearing, only one syncro on the shaft for 5th, reverse gears lock to idler gear
Rev idler gear
1st thru 4th gear clusters on main shaft - all have syncros & move unless syncro is slid over & locked
why would 1 to 1 even matter w/a ratio already so close?
#9 Re: 5 speed question
revhead001 Posted on: 2009/6/26 23:30
With the box apart it is even easier to get the exact ratio. The only gearbox's that have 1:1 5th will be the ones that 5th is the input and drop gear ratio's. The one pictured above is a 60A with 5th and reverse being together.
#10 Re: 5 speed question
ddgonzal Posted on: 2009/6/27 0:36
In other words, if it has a gear for 5th, it is not "5th direct" transmission.
In the regular 4-speeds, there is no mechanical gear for 4th, instead the input shaft locks to the output shaft (direct drive). The counter gear has 1,2,and 3 on it.
In 60 and 63 five speeds, there is a mechanical 5th gear. Fourth is direct, fifth goes through a gear that meshes with the countergear. The counter gear has 1,2,3,and 5.
In 56 series 5-speed, fifth is "direct". There is no counter gear for fifth. When in fifth the other four gears spin freely on the main shaft. Counter gear has 1,2,3 and 4th.
