Browsing this Thread:
1 Anonymous Users
a14 questions |
From Adelaide
I just bought a 1000 coupe with an a14 in it.. it hasnt been started for a while, and im scared if i start it I may damage it, what are the best ways to go about relubing everything, and just general stuff I need to know so I dont blow the rings or damage anything once the alternators hooked up on tuesday.
Posted on: 2003/8/28 14:16
Re: a14 questions |
From Little Rock, AR
Pull all the spark plugs and pour some oil down each cylinder. Take off the rocker cover and spread a little oil across all the rockers (don't overfill though), put some fresh gas in it (not required), make sure there's adequate ventilation and a fire extinguisher handy (better safe than sorry). Other than that I've started A series right up after sitting for months with no delay. Also charge the battery up and have jumper cable handy. Good luck!
Posted on: 2003/8/28 14:28
Re: a14 questions |
From Adelaide
how much oil down the plugs? and what sort of oil? engine oil, thanks heaps for your help, it should sound pretty tuff without an exhaust :P
Posted on: 2003/8/28 14:44
Re: a14 questions |
From Brisbane Australia
I would also crank it by hand a few times to coat the bore with oil and bolt on an exhaust!!
Posted on: 2003/8/30 0:04
Re: a14 questions |
From Auckland N.Z
unplug the sparkplugs and turn it over a few times (10sec) without detonating. this, along with the oil you put in should get things movin g and ready to start.
Posted on: 2003/8/30 0:58
Re: a14 questions |
Registered Users Contentmaster Usermaster
Yes, engine oil. Just put "some" in the holes, then remove the distributor wire from the coil, and crank it over 10 secs as Quinn says. If there is too much oil, this gives it a chance to run back out the sparkplug holes.
Then put the plugs back in and fire it up.
Posted on: 2003/8/30 5:18
Re: a14 questions |
From Adelaide
thanks for your help guys, btw it does have an exhaust, well half of one just manifold and pipe, the dude I bough it off was a tripper, he was telling me to put a straight 2.25 exhaust that side exits with no mufflers...
Posted on: 2003/8/30 12:50
