A14 parts: 1393cc vs 1397cc ?
Sidney asked Quote:
Posted: 2009/7/9 13:48 Updated: 2009/7/9 14:03
A14 1397 AND A14 1393?????????
I HAVE A 77 B210 WITH A A14 1397 ENGINE . WHEN I LOOK FOR PARTS I KEEP FINDING PARTS FOR A14 1393 ENGINES . I NEED A VALVE THE ONLY ONES I CAN FIND SAY THEY A14 1393 WILL THEY WORK ON MY A14 1397????? AND WILL OTHER 1393 PARTS LIKE HEAD SETS WORK LIKE A FEL-PRO GASKETS #HS 21199 PT-1 THAT SCHUCKS SAID WORKS ON A14 ENGINES 1393? NAPA SAME PART SAYS IT FITS 1397? IS THERE A 1397 AND A 1393 IN A 77 DATSUN B 210 ARE THE PARTS THE SAME ???? THANK YOU SID
Posted on: 2009/7/10 2:44
Re: A14 parts: 1393cc vs 1397cc ?
From Coondle, WA Australia
didnt know there was two different capacitys for the a14. Is this the economy version of the a14 vs standard?
Posted on: 2009/7/10 2:52
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Hi Sid, welcome to the club.
All A14s are 1397cc, so those other places got it wrong. My 1977 B-210 factory service manual says 1397cc too. See A14 Engine.
In any case it should work on your A14, depending on the year the part maker specifies.
Fel-Pro 21199 works on any USA Datsun A engine, 1975-1982, including A14, A15, and A12A. I think it is the Fel-Pro PermaTorque gasket, which is an OK gasket. And a bit less expensive than a genuine Nissan gasket.
HS means head set, which may not fit all those years. Intake manifolds are two different types.
Posted on: 2009/7/10 3:01
Edited by ddgonzal on 2009/7/10 3:18:31
