Browsing this Thread:
1 Anonymous Users
offset |
From Ballarat, Victoria, Australia
will these rim dimensions fit a 1200 14x6 4x100mm stud pattern, 1.3/8" 35mm offset, cheers
Posted on: 2003/7/28 10:07
 -1200 4 Door Sedan, 2Pac Aruba Blue, Custom White Interior, OBX Racing Seats, SONY Head Unit, FUSION Speakers, 14" Bathurst Globes, Lowered, Powered By: A15 with Twin 40s,
Re: offset |
From Warwick, QLD
Nope the Datto PCD is 4*114.3mm or 4*4.5inches
Otherwise it should of fitted nice Cheers Damo
Posted on: 2003/7/28 10:26
Drive It Like You Stole It Every Car Has 500hp In The Wet Team NEW SKOOL
Re: offset |
is this closer enuff 4 x 114 ...tha offset is 38...cheers
Posted on: 2003/9/1 12:55
Re: offset |
From Christchurch, New Zealand
Nope they wont fit as said above.
4*100 is on alot of modern small cars mainly hondas (civic integra) and also some stuff like Mazda MX5s.
It cant be close enough its gotta be correct
Posted on: 2003/9/1 12:58
Re: offset |
From Warwick, QLD
Yeah 4x114 is the right PCD, 38mm offset is a FWD offset which just means your rims will sit inwards more then others, the more the number the more the wheel sits inwards of your guards
Cheers Damo
Posted on: 2003/9/1 13:07
Re: offset |
From Sydney, Australia
14x6 rims need about 15mm of offset to fit on the front when you are using stanza lower arms. You can get away with 0 offset (like 510s) for the rear @ 6inch width.
So unfortunately when using the stanza front arms, the wheel offset specs change from front to rear. This is why flares become important after fitting larger brakes, where you need use 14 or 15inch wheels. Especially for those of us that want to fit racing slicks under the guards.
Chris
Posted on: 2003/9/1 13:39
