« 1 2 (3) 4 »
Re: crank knife edge
I haven't ever tried it myself, but paint definitely works too. I have to admit I'm not super knowledgeable about paint, but from what little I do know, you'd probably have to use epoxy enamel type paint - as it's one of the few I know about (which doesn't mean it's the only one, just the only one I know for sure) that is petrol/oil resistant. It's a tough call. Given the amount of oil misting (even on an engine with a well designed sump etc) rust wouldn't be a problem either way. Plenty of aftermarket sumps are painted on the inside - by looks it might be the primer sealer that Steveo's mate has used. I _think_ I recall David Vizard mentioning it in one of his books, but that's a vague recollection. But if that bloke has mentioned it, it's a pretty safe bet it works and lasts. I dare say that if you are going the paint route (and I see nothing wrong with it) I'd go beserk with the prep before hand, washing it with solvent, then hot soapy water, then solvent again (probably acetone for the last repetition as apart from being a decent solvent, it tends to help evaporate any trace amounts of water. Basically you'd want the block to be surgically clean to give the paint the best chance of attaching itself. One thing I have nfi about - I wonder whether paint would stick better to a rough cast block surface or one a little bit smoother (not quote polished smooth, just not as rough as std)....
Interesting stuff indeed.
Posted on: 2009/7/16 7:10
John McKenzie
From Christchurch NZ
The paint all the hot rodders use to paint inside their blocks is called Glyptol. (Or glyptal?) it's used to paint inside electric motors, and is apparently pretty tough stuff. I might talk to my engine machinist when I see him next.
Posted on: 2009/7/17 9:31
Forced Induction!
From newcastle, NSW
yes Bart is right, the proper stuff is called 'Glyptal paint', and is for use eletrical windings.
ALOT OF HOTRODDERS USE IT FOR THEIR ENGINES, HERES A BIT OF INFO.
The pics i posted in my earlier post was from a member on this site, it is an A14 race motor. I just read through the post that it was posted in and it was hot tanked and the paint he used was just 'DULUX PRIMER SEALER' its not the proper gylptal stuff. Not sure how well it would work but the main reason he paited it in that way was to stop any casting from coming loose.
heres the other pics-
Posted on: 2009/7/17 11:44
You will find similar paint in the insides of most old gearbox's and diff's. Used to stop trace amounts of casting coming apart. Very small granules like sand. Falcons have this problem with their engines, all the debris from the cooling ends up in the radiator and blocks it causing massive overheating problems. Some do it and some don't. I guess it comes down to if your falcon was built on a friday or monday!
Posted on: 2009/7/17 13:22
I remember when that pic was posted, and wondering how long it lasted. I too would be sh1t scared about the paint coming adrift from the block, and creating havoc inside the motor. I supose that the inside of the block is going to be quite rough, thus giving the paint a good key to stick to. But also offering many nooks and crannies for paint adhesion preventing impurities to hide in.
Posted on: 2009/7/20 10:33
Forced Induction!
From Cape Town South Africa
I think Ill play it safe and do it the hard way! I know myself if I should paint it it would bother me till the end of days
Posted on: 2009/7/20 13:54
Racing started the day the 2nd car was built!
I spoke to my engine machinist today when I picked up my freshly machined block. he said it's uncalled for on a japanese engine. The castings are so good that it just isn't warranted. I have heard of some people having the indside fo their blocks ceramic coated.
Oh to have an unlimited budget aye?
Posted on: 2009/7/22 8:13
Forced Induction!
From Adelaide, Australia
I do regret painting the inside of my sump, I just wanted to be 100% sure it was sealed, I used plenty wax and grease remover cleaned well and used vht engine paint so fingers crossed I don't get any paint coming away in there.
Posted on: 2009/7/22 8:21
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
A ceramic coated block hectic! I love my datsun but I wont go that far. That would more expensive that what I paid for my motor and gearbox lmao!
Posted on: 2009/7/22 8:25
Sean we have seen your work you have done so far and judging from that your sump will be fine
Posted on: 2009/7/22 8:31
« 1 2 (3) 4 »
