1000 Wagon ??
From Mandurah WA
Could someone provide me with the specs please? not like the engine ones but how much does it weigh, what sort of engine and gearbox and weather or not the A12 and 4sp box will fit it ?
thanks.
Posted on: 2003/9/4 10:53
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: 1000 Wagon ??
From Perth
Standard wagon 645kg. Deluxe wagon 665kg.
A10 engine factory and any of the A series is a virtual straight bolt in. Some require minor engine mount adaptors.....details can be found somewhere here on the site.
If changing engine make sure you change the box also as they run a 160mm clutch that is marginal with a 1000 let alone a larger engine. Use the 180mm 1200 clutch. R137.
Clutch cable from 1200 should be used and mount off firewall of 1200 also.
My coupe has A12 and 4 speed. My brother has A15 and 4 speed in his wagon. Plenty of them around.....its all reasonably easy to fit.
Disc brakes if you get real keen http://www.datnet.org/new/techinfo/1000brakeupgrade.shtml
Posted on: 2003/9/4 11:42
Re: 1000 Wagon ??
From Mandurah WA
you probreally didnt see the quokka today there is one for sale $150 licenced just needs new engine ;) and my A12 is nearly ready plus i got all the A12 Fruit (not the stuff you eat)
Posted on: 2003/9/4 11:58
Re: 1000 Wagon ??
From Hobart Tasmania AUS
I've got a 68 wagon that im doing up my L's. it.s a great machine. Everyone in the family got a 1000 2 door sedan 4door sedan and my wagon. Does any one know what the best engine I can put in it is?
Cheers.
Posted on: 2003/9/4 12:14
Re: 1000 Wagon ??
From Mandurah WA
Depends there mate..
Some people like the A series vintage..im not to sure on the engine bay in the 1000 but you could defintally fit a A15 with webbers and extractors ;) nice lumpy cam and should be do some moving:)
Or look into a L series eg the L20b :) but im not too sure on how it would fit..
Posted on: 2003/9/4 12:19
Re: 1000 Wagon ??
From Canberra, Australia
L series would be too hard to fit.
Go for A series.
I believe that an A12 from a 1200 will bolt straight into it.
A12 from 120Y/sunny, A14, A15 will need adapter plates.
At the risk of starting debates, I know that there are a few 1000's with rotary's in them.
Aparently they are easier to fit than CA's and stuff...
Posted on: 2003/9/4 13:37
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
Re: 1000 Wagon ??
Thats right an A12 fits fine my dads got one in his 1000. what are adapter plates?
I want a 5 speed gearbox but what can i get one from?
Posted on: 2003/9/5 0:15
