« 1 (2)
Re: Switching a vg30 to Carburetor
From Los Angeles,CA. USA
Have you contacted VG30.com?? If not check out their web-site!
Posted on: 2009/7/24 8:27
Not too shy to talk
I am getting the whole car complete a 1984 300ZX, frame is buggered and cannot be registered. I plan on putting the engine and auto trans into a 1200, and every time I have seen a swap it says you need the saudi distributor, so I assumed I could not use the original when I switch the 300ZX to carb., As for the modifying the manifold for a carb, that is the easy part.
Posted on: 2009/7/25 4:03
From bend oregon
check out www.dimequarterly.com they have some conversion tips that may help or search it
Posted on: 2009/7/25 6:12
coming through hard
Only a suggestion...Why don't you get a G.M. 6 cylinder HEI distributor and the VG30 distributor and combine them to make one!
Use the lower part off the VG30 (shaft and gears) and the upper part off the GM distributor (Ignition module, trigger and Cap)...shafts can be joined with a roll pin!
I have two distributors that were converted on a '59 Studebaker V8 and a '52 Henry J 6 cylinder. Check out this web-site www.performancedistributors.com/index.html
Just make sure you have enough clearance with the distributor cap! Heck...if you can't source this distributor use a Chrysler unit or any pre-fuel injected model!
Posted on: 2009/7/25 6:55
Not too shy to talk
i figured i would end up building my own. I like that site, they have cheap rev limiters, I wonder what quality they are.
Thank you sooooo much, you are the first person that has been helpful. I am just a young gun 23....lol
p.s. I don't know why I never thought of that, it seems so simple thats I am so stupid not to have thought of it lol
Posted on: 2009/7/25 7:42
« 1 (2)
