« 1 (2)
Re: Datsun B210 overheated
You can test the radiator cap with a special hand pump designed for it ...
Or just swap it for one off a Holden ... they are all pretty much the same. I'm partial to 7lb caps (to keep pressure in the old radiators lower) and a 180 degree thermostat to keep pinging away with regular (low octane) fuel.
Posted on: 2003/8/27 3:08
Okay, here is the update so far. I got my car to the nearest garage and guy told me he found a small leak in the water pump. He said he would replace the pump, thermostat, and do a complete flush to see if it solves the overheating. I am biting my nails at the moment awaiting the phone call because I am afraid I did damage to the head gasket. It should be ready sometime today, but i am anxious for the call!
Posted on: 2003/9/4 22:35
From Tas
Don't Stress. $%@ Happens!
Even if it is the head gasket its no huge drama. Probably one of the best little motors to do a head gasket on - nice and easy.
There should be more than enough info on this site and people willing to help you out if it is the head gasket.
Lets just hope its not
Posted on: 2003/9/4 23:56
From durban, south africa
yeh ask me i had to change mine four times in about two months after my rebuild long story i'll tell you later in life. lets just say i blocked my oil feed to the rocker shaft.
nicholas
Posted on: 2003/9/5 6:15
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From Millgrove Vic OZ
Nicholas that avatar is damed hypnotic and I am becoming obsessed damn it.
Posted on: 2003/9/5 13:02
Cheers Feral
Chad
If you are interested in Datsun cars, but don't even know where the thermostat is, then i recomend that before you do any more damage, that you
1. Get yourself one of those Gregory's repair & service manuals. They are not too expensive & are a VERY good investment.
2. READ IT. Then read it again.
3. Follow the instructions to the letter
The cost of the book will be recovered many times over in the damage that you will NOT do as a result of NOT knowing how to find or fix things.
Three simple steps. Get the manual, Read the manual, Obey the manual.
Net result, money saved, greif avoided.
Chris
Posted on: 2003/9/6 9:17
« 1 (2)
