« 1 (2) 3 »
Re: Finally, my rebuild underway, panel beating first...
From Harare, Zimbabwe
Ok guys, I am starting to wonder if i have bitten off more than i can chew!
I've taken the engine out & it sitting in immy's garage (ta for that mate!) & i wrote up a list of wht i would like/need to sort out on my datto....
Tell me what you guys think:
ITEM Price
Fuel pump 10
Oil pump 10
Water pump 10
Gasket set 25
Main bearing 22
Big-end bearing 13
Oil filter 5
Fuel filter 2
Cone air filter 30
Tapet cover clean 5
A14 pistons/rings 95
ENGINEERING
Cam grind 50
Flywheel lighten 20
Crank balance 20
Block bore 50
Head recon/port/polish 30
CONSUMABLES
Engine oil 25
Coolant 15
Engine cleaner 10
Fan belt 5
Silicone 5
Spark plugs 20
HT Leads 20
Total so far US$500.!!!
& thats just on my engine!!!! so im upto US$500 on my engine & US$350 for the panel beating & respray....
I have another list of stuff that needs to be done (no prices though):
BODY / MECHANICAL
Shocks / coils
Exhaust system
Recon wiper motor
Recon starter motor
Recon alternator
Wing mirrors
Rearview mirror
Brakes - relining/recon
seatbelts
Headlight upgrade
Spotlight install
Rims
Tyres
Fender flares
Upholstry
Front seat swap
Dash board swap
Sports pedals
Decals
Window tint
What do you think of all this now? I could possibly buy a car for cheaper than i can recon my 1200!!!
Posted on: 2009/7/31 12:19
Edited by Ethan on 2009/7/31 12:35:02
"Make a plan!!!"
From Cape Town South Africa
Is that all in us$ and when you say balance crank is that just the crank or the rods pistons flywheel presure plate and front pully because thats what it should consist of. Cheers
Posted on: 2009/7/31 12:32
Racing started the day the 2nd car was built!
all prices in US.... & as i understood it, the cank grind will be to balance the lightened flywheel .
Posted on: 2009/7/31 12:59
"Make a plan!!!"
Posted on: 2009/7/31 13:02
"Make a plan!!!"
From Cape Town, South Africa
1000Coupe Please explain: good progress there, make sure u use rust converter and fish oil or similar on the back of the panelsover a wider area than the plates u have put in,
The "oil" part please; is this some panel beating magic. I'm feeling quite dump here, as far as my knowledge stretch, oil on the surface of parts that needs a spray job is bad.
Posted on: 2009/7/31 14:50
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Its not for the side you going to spray it for the back of the panel. Or thats how I understand it
Posted on: 2009/7/31 14:57
Ok, I was really pissed off with the panel beater coz he was meant to have test sprayed an area & waited for my go ahead to spray the whole car. I think his partner was getting impatient coz my car has been there a while now.
Ive attached some #OOPS#ty pics that i took with my phone:
there wer a couple of things that i still wanted done like blanking the hole where an alarm switch was fitted on the passenger door, etc....
what you guys think of it?
jpg  Image011.jpg (109.76 KB)
10585_4a78416caf04e.jpg 557X480 px
jpg  Image010.jpg (99.39 KB)
10585_4a7841f9d5ee4.jpg 600X480 px
jpg  Image012.jpg (76.80 KB)
10585_4a78425839af1.jpg 533X480 px
jpg  Image013.jpg (97.10 KB)
10585_4a784738ac1bd.jpg 572X480 px
jpg  Image014.jpg (96.78 KB)
10585_4a7847e71b594.jpg 603X480 px
jpg  Image015.jpg (70.86 KB)
10585_4a7848249e622.jpg 510X480 px
jpg  Image016.jpg (80.38 KB)
10585_4a78486b196a8.jpg 600X480 px
jpg  Image017.jpg (103.01 KB)
10585_4a7849951f5bd.jpg 600X480 px
jpg  Image018.jpg (115.29 KB)
10585_4a784a1bd5f41.jpg 600X480 px
jpg  Image019.jpg (97.98 KB)
10585_4a784a5ea859e.jpg 600X480 px
jpg  Image020.jpg (94.55 KB)
10585_4a784a931a0f2.jpg 600X480 px
jpg  Image021.jpg (85.91 KB)
10585_4a784b8ed27a0.jpg 600X480 px
Posted on: 2009/8/4 15:55
"Make a plan!!!"
no comments, crit, etc...
Posted on: 2009/8/5 10:16
"Make a plan!!!"
From Adelaide, Australia
Looks really nice mate, nice front spoiler too. Is it for a 1200 or something else fitted up?
Posted on: 2009/8/5 10:41
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
i think its for 1200... from how it fits there was no mods needed.
Posted on: 2009/8/6 12:48
"Make a plan!!!"
« 1 (2) 3 »
