Has anyone put a nitrous setup through an A-series?
From newcastle, NSW
As the tittle says, Has anyone or know of someone who has put a 'fogger' system in an A-series?
This question comes after watching the grunt files!
Posted on: 2009/7/31 15:12
Re: Has anyone put a nitrous setup through an A-series?
From Harare, Zimbabwe
i was wondering about that myself.
I used to belong to minifinty.com wen i drove a mini & those guys would NOS their minis. dangerous stuff!
Posted on: 2009/7/31 15:18
"Make a plan!!!"
From sydney
i reakon it would only be worth it wiht a supercharger or turbo. just a NA engine it wouldn't be worth it. but i would like to see one to seee hoe it goes
Posted on: 2009/7/31 16:38
From Cape Town South Africa
Here in sa we see that alot on the v8 cars and I have seen a few honda vtec car with those systems and they all N/A So yes I think it should be something to see on a a14
Posted on: 2009/7/31 19:11
Racing started the day the 2nd car was built!
Sure, many have done this. I recommend a 25HP shot for a stock A12.
Ernie has an estimated 75HP setup on his A15, but i suspect he has forged pistons and/or it's not really 75HP. It gives a noticeable increase in power (for a few seconds).
Posted on: 2009/8/1 7:44
From Townsville, Qld
There were two ways I was thinking of playing with this idea, possibly just with some methanol for top gear fun. Firstly would be to use the DGV adaptor plate as a fogger plate by drilling into the sides and installing some jets. The other way I'd rather go is using my A14 manifolds' emissions ports on each arm as nos\meth\sugar\ inlets. Either way I don't think you would need much pressure to get a result because the vacume would do some of the work for you.
Posted on: 2009/8/1 8:07
Quite a regular
From Adelaide
I had a direct port nitrous setup on my 1200 coupe before I put a ca18det in it, I had a 32/36mm webber, extractors and exhaust and electronic ignition, I used 40hp nozzles (they use theese nozzles on harleys).
I had the car dyno tuned and it had 116hp at the wheels, actually went really well but the nitrous bottle doesnt last long and it is not cheap to refill the bottle, about 100 dollars to fill it up.
Posted on: 2009/8/1 8:18
