BW 120y diff into 1200 sedan
Quite a regular
From Sydney
Hey boys and gals. Was just wanting some help on the topic. I have read the wikki but just wanted some extra info. Is it hard, cost much etc etc? Whats involved? Worth it?
By the way its a borg warner axle, thanks.
Posted on: 2009/8/6 3:20
Re: BW 120y diff into 1200 sedan
same as any B210 to B110 axle swap:
* You need the axle assembly, matching tailshaft and brakes cables/line, and leaf spring mounting plates and U-bolts
* only 120Y sedans came with BW68, so that's good for you B110 sedan. The use the same mounting and shock configuration. Coupes are another story
* the leaf spring-to-axle housing locating pin may need messaging
There's no cost involved, in other words no machining/welding/cutting is required.
Or so I hear...
Posted on: 2009/8/6 4:06
