Re: draw through turbo setup for a series
From newcastle, NSW
Are you using ?A12-A14 or A15?
Not that it matters much, perfect size turbo is a T2 off a ET, EXA pulsar (E15T) but it runs out of puff late in the rev range? Personally i use a T25 off a CA18DET, its a little laggy but its not the noticable. You can drive around normally in traffic without hitting boost but soon as you wat a bit of gusto the turbo winds up and it boosts like a freaking hurricane!!!
Are you going spend some money on the engine internals? and head work?
Posted on: 2009/8/9 15:27
From Brisbane
i have an a12
yeah t25 sounds like fun
not sure yet itd be a good idea what should i get done? i thought your meant to have low compression?
Posted on: 2009/8/9 15:35
From Melbourne, Oz
Yeah I think its something like 7.5:1 that ya want, but arent 100% sure need to make up a spacer, or I think some hav got away with an a14 low comp head and maybe an extra gasket. can allso do stuf like resces valves and open(grind out) chambers to some degree
Posted on: 2009/8/9 15:46
"I hav achieved wood"
From newcastle, NSW
There are a few ways to lower the compression ratio, you can use a shim(spacer) plate that goes in together with the head gasket. i have also heard of people using 2 head gasket to gether to do the same job. If you're planning to built a reaonably low boost set-up this method is fine as long as you don't go overboard.
Or you can have the pistons and/or head machined to reduce the compression ratio,i.e dishing the pistons etc, i would recommend this method for higher boost applications.
If your doing any sort of engine work i would recommend a suitable turbo cam, i'm pretty sure you can get on from a decent cam place, crane or crow would be a good start. I would recommend a full rebuild if you're going that far.
Posted on: 2009/8/9 15:49
From Brisbane
very helpful thanks mate
Posted on: 2009/8/9 15:51
From Cape Town South Africa
I had a little 1.5 honda civic that I ran on 10psi with all standard internals on with 9.2 comp ratio it had a t 2.8 off a saab and made 141kw on the fly and 272 nm so I think keeping the suck trough setup in mind 8 to 8.5 should be fine at about 7 psi just always! Make sure you have enough fuel to your motor or you will! Melt pistons. Good luck its gona be fun!
Posted on: 2009/8/9 15:56
Racing started the day the 2nd car was built!
From newcastle, NSW
no worries jarrydsNIZ12!
Yeah thats right superbin, i wouldn't go anything over 10psi on stock internals on an A-12. 8PSI is a good starting point.
Posted on: 2009/8/9 15:59
From bundy, QLD
you could also get your head cc'd, with the t25. And as the guys say... nothing over 10psi so be safe enough.
Posted on: 2009/8/10 5:31
"71, 1200 Sedan a.k.a- old_spool- (project)
73, 1200 Sedan
71, 1200 sedan (parts car)
89, swift gti (gone now)
90, swift gti
From bundy, QLD
if you want a safe bet though, (and probably the cheapest) go a t2, plentaful, cheap, easy to get parts for. and as long as you get it hi-flowed should have enough power for you. this is my opinion though..
Posted on: 2009/8/10 5:34
73, 1200 Sedan
90, swift gti
From Brisbane
how much power would i end up with just a ball park figure?
if i was to run a t2
Posted on: 2009/8/10 7:00
« 1 (2) 3 »
