« 1 (2) 3 »
Re: 120y Auto Shaft To Stanza Box No Go, Help ??
From Armidale N.S.W
O.k but the only thing in my measurements is that a TRX series 2 5 speed bellhousing (got one here) will put the box back where i started as its a longer bell housing. Just pulled a tailshaft out of the bluebird SR20 it says on it 120y Auto but must be H150 as its got a different end on it (diff end)There same tail shaft diff end as H165 ay ?
Posted on: 2009/8/10 4:15
73 1200 wagon SOLD
try here
i thought h145 was more like h165 than h150 flange
Posted on: 2009/8/10 5:05
From Adelaide, Australia
H150 flange is the same as H165.
Posted on: 2009/8/10 6:48
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Armidale N.S.W
Yep H150 is same as H165. So may i ask what diff gearbox and tail shaft are you running Sean ?
Posted on: 2009/8/10 7:01
73 1200 wagon SOLD
63a dogleg 5spd with H165 ute diff, stanza tailshaft had to be cut down when I moved the engine back 3-5mm from firewall and new sump.
Brown car stanza 4spd with H145, standard 1200 auto tailshaft.
Posted on: 2009/8/10 7:04
IPRA Build
From Armidale N.S.W
Damn it, scratches head. Looks like a stock diff is going back in.
Posted on: 2009/8/10 7:08
73 1200 wagon SOLD
how is the h145 going with the L power?
wouldnt h150 or bw with auto tail shaft work?
Posted on: 2009/8/10 7:14
Yeah they should all work in the right combo as long as the engine isn't too far back.
I had a BW with BW 1200 auto tailshaft in before the H165 ute diff went in there.
The H145 centre has been fine, although I didn't really do a stand stills or hard launches on it only a few ringys and stuff. the cars sat doing nothing at the moment so I can do any damage to it.
Posted on: 2009/8/10 7:20
IPRA Build
yeah i have worked on that info in sourcing all my parts too.
the length should be the same in all the combos as the gear box in aseries is in same spot and so is the diff, so if you use h145 h150 or bw, the total lenght should be same.
onlt one different is h165 but you siad would work with h150 shaft.
weird.
Posted on: 2009/8/10 8:07
You'll have to shorten the H150 shaft though as the H165 centre is longer.
Posted on: 2009/8/10 8:09
IPRA Build
« 1 (2) 3 »
