A12 head on A15
From Griffith
I can get a a12 head cheap with carby and extractors , was just wondering wether its worth wacking it on my a15 to give it some high compression , run the extracters along with a weber 32/36. is there any modifying to be done to get it to fit , or any complications that is stoping me from doing it?
Posted on: 2009/8/17 9:27
Re: A12 head on A15
From Griffith
Anyone , im sure someone has tried this before ?
what pushrods will i have to run still the a15 rods due to the length of the block?
Posted on: 2009/8/17 11:14
Re: A12 head on A15
From Adelaide, Australia
Is the head from a early A12 (1200 or 1200 ute) or from a later 74+ (120y, 1200 ute, sunny)?
Posted on: 2009/8/17 11:38
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Re: A12 head on A15
From Griffith
its out of a 120y unsure of what year though didnt take much notice
Posted on: 2009/8/17 11:52
Re: A12 head on A15
If you plan on running the engine only up to 3500 RPM this will be a good swap. The A12 small ports will keep air flow high, resulting in extra torque (low RPM horsepower) and good throttle response.
You will lose compression as the A12 chambers are larger than the A15 chambers. The A15 has has large dish in the pistons rather than large CC chambers.
A14 and A15 always use the long pushrods, regardless of which head you fit.
Posted on: 2009/8/17 18:52
Re: A12 head on A15
From pooraka,,adelaide
i did this to my a15 one i used the a12 pushrods u cant really notice muchit seemed to have more tourqe
i ran this for about 3 months
Posted on: 2009/8/17 21:28
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
Re: A12 head on A15
From Griffith
thanks guys i dont think ill bother then especially if i am gunna lose compression, i think ill just pinch the extractors of the motor and run them on my a15
Posted on: 2009/8/17 23:04
