« 1 2 3 (4)
Re: 77 B210
From Vancouver Canada
my hanes manual says that if temp and fuel gauges are faulty at the same time it may be the "voltage stabilizer" also hers is another snippet from the manual to check if the temp gauge is working
"Disconnect the spade connector from the transmiter unit,switch on the ignition when the gauge should read COLD.Now ground the cable to to the engine block should indicate HOT.(i,mm guessing warm up the engine for 15 minutes or so)this test proves the gauge to be functioning and the fault must therefore lie in the cable or transmitter unit."
hope this helps
Posted on: 2009/8/22 3:10
slow and steady wins the restoration war????? :)
Re: 77 B210
Good info. When you ground the temp sensor wire... disconnect at the engine sensor and ground it ... the gauge should read HOT regardless of the actual temperature. This test bypasses the temp sensor. Turn key to IGN to test.
The 'voltage stabilizer' is also called the 'instrument panel voltage regulator' and is inside the gauge cluster.
Posted on: 2009/8/22 3:27
Re: 77 B210
any help for removing polution control is this an option for me? http://www.speedycarparts.com/sku/Nis ... 816&cpncode=17-35851072-2
jpg  air drive copy copy.jpg (149.26 KB)
12259_4a8f58e084ba0.jpg 640X480 px
Posted on: 2009/8/22 3:33
Edited by deltapeco on 2009/8/22 4:18:51
Re: 77 B210
anopther question..... will ball joints from a 74 fit my 77 (120y/b210)found some online
http://www.partsgeek.com/ntparts/1974 ... ign=PartsGeek+ShoppingCom
Posted on: 2009/8/22 3:43
Re: 77 B210
From bend oregon
loose the air pollution crap and i think 74 is the bastard year so it might not work
Posted on: 2009/8/22 4:41
Re: 77 B210
ah that bastard year thingy my manual says 73-78 cant believe everything ya read these days...heres some pics i just took tryin out my new camera.... it rained earlier so shes a little wet.(not bad for orginal paint)
jpg  fins.jpg (130.77 KB)
12259_4a8f76a6aa6a4.jpg 640X480 px
jpg  rear emblem.jpg (140.06 KB)
12259_4a8f76b7b7c44.jpg 640X480 px
jpg  right front.jpg (103.80 KB)
12259_4a8f76c6552ec.jpg 640X480 px
jpg  right rear.jpg (122.35 KB)
12259_4a8f76d7a692c.jpg 640X480 px
jpg  side emblem.jpg (149.61 KB)
12259_4a8f76e71d77a.jpg 640X480 px
jpg  smokin hatch.jpg (156.32 KB)
12259_4a8f76f79af55.jpg 640X480 px
Posted on: 2009/8/22 5:41
Re: 77 B210
B210 was first manufactured in 1973. The 1974 model year (north america) started in October 1973.
The 1974 MY (model year) was unique:
* A13 engine, one year only, in north america
* Small H145 differential (same as B110)
1975-1978 went to the A14 and stronger diff exclusively for north america.
Just about everything else is the same though.
Posted on: 2009/8/22 6:00
Re: 77 B210
thanks so much last time I ha passion for a car as much as I do now is when i was 19 and had a 1964 Impala 327 SS factory 4 speed.......I sold her for 2 grand when i was 21 (ya I know STUPID) she is a 40k car now.well this little Artifact is gowin nowhere lol. have you seen this site?
http://www.partsgeek.com/ymm/1977/nissan/b210.html
they seem to have alot of bits and pieces that they claim are OEM.
alot of parts i want to order but am leary of paying for stuff online........... pics seem real.
seatle you are very close to us we are in Vancouver ther is a Datsun run in september bring up some buddies
here is the web site. http://www.dnbc.ca/
Posted on: 2009/8/22 6:38
« 1 2 3 (4)
