« 1 (2)
Re: Modded A15 problem
From Melbourne, Oz
I think they may be silvia strut tops, hav seen them used beffor.
Posted on: 2009/9/1 14:18
"I hav achieved wood"
From Malaysia
I recall tat it was from ae86....
But after i install it to the std b310 suspension,the front looks high...
So i adjust it down to the max but still looks high...
Change the spring to stiffer n lower 1...
Then the absorber was like no play after installing 1 inch bump stop....
Posted on: 2009/9/1 15:04
B110 1972 Modded A15
single spring good enough or i must use the double 1???
Then engine cant rev past 6k rpm
A15 valve springs are only good for a little over 6000 RPM. For higher RPM, Nissan Competition sold dual springs. The lighter A12 valves could go about 6400 with single springs. But the A15 has larger valves. And if yours are worn from age and use, they might not even rev to spec.
Any other engine's single valve spring(heavier) tat i can use??
Yes, but your cam will wear out faster. Some use Austin Mini competition springs on the Nissan A Engine.
Dual valve springs are the best.
Posted on: 2009/9/1 19:16
From Malaysia
Thank guys....
U guys really helped me....
Posted on: 2009/9/2 8:48
From Malaysia
Retuned my engine d...
The ignition timing were too much when i plug in the vacuum...
Static 12 deg but wif vacuum it goes bout 25 deg...
Adjust it to 10 deg(static) n wif vacuum 15 deg...
After the adjustment i found tat the nosedive prob occur under 2000rpm...(previous was 2500rpm)
Confused....
Posted on: 2009/9/4 4:20
« 1 (2)
