a14 pushrods please help
From Gold Coast, Australia
hey guys im in real need of some pushrods for my a14, got it at the mechanic at the moment and one of the pushrods is bent. trying to find aftermarket ones if possible.
if anyone can lend a hand, know a company or a place to source, it would be a great help
thanks
Posted on: 2009/9/9 1:17
Re: a14 pushrods please help
From Freo
where you located??
Posted on: 2009/9/9 1:53
A15 PSI Project Motor
'72 CB750k,
From sydney australia
Dundee1000 is an agent for BProjects, so if you're in Australia I'm sure he can help. Seriously, I've always thought you could straighten the pushrods, at least close enough to be usable. I've seen people straighten axles, so a pushrod should be fixable, as long as it's not hollow. I'd put it between 2 points & rotate it to measure how bent it is, then using a press, push down on the high side. I'd try a drill press with a block of aluminium in the chuck & something to support the pushrod. using the drill press should make the force so small that it wont damage the pushrod. I'd try & get the pushrod as straight as possible, but not get too perfect. BUT, I'd only do this if it was a street motor. If it was for a race motor I'd go to a Nissan dealer & get a new pushrod, which are the same for an A15 as the A14.
PS the guy who straightened the axle for me was a certified(able) jet mechanic & he used to straighten the shafts on the jet engines all the time. With the axle he took a light skim on the axle face after the straightened it, so the drum was square to the axle. Saved me from trying to find a late 1200 ute axle.
Posted on: 2009/9/9 5:07
From Perth
Whats the length of an A14 one
I gave at least one away and probably have more if you can tell me what length
Posted on: 2009/9/9 7:14
From Freo
A14 are the long ones, A12 are short,
Posted on: 2009/9/9 7:29
'72 CB750k,
dundee's on the money, they're longer than a12.
im on the gold coast mate, able to send me a PM?
Posted on: 2009/9/9 9:22
From Perth
I know that.... but I don't know what I have
geeez
Posted on: 2009/9/9 9:58
From Freo
when have you ever had small block stuff Neil.. ha ha
Posted on: 2009/9/9 10:06
'72 CB750k,
