Flywheel bolts ?
From Delaware, USA
Are the automatic flywheel bolts the same of the standard one ? I'm converting 2 engines from automatic to shift but I only have 1 set of standard bolts and 2 sets of automatic flywheel bolts :(
Posted on: 2009/9/12 20:13
Re: Flywheel bolts ?
From Christchurch NZ
I just use 12.9 High tensile capscrews. I'm told that the early motors (front dizzy?) have imperial threads in the flywheel bolt holes.
If you do use capscrews, check that the heads don't foul on the center hub of your clutch plate. I had some (Only just) touch the hub, and it led to a bit of clutch slipage.
Posted on: 2009/9/12 23:13
Forced Induction!
From Freo
you can buy NEW genuine ones,
don't take the risk, use the genuine items, !!!
Posted on: 2009/9/13 1:49
A15 PSI Project Motor
'72 CB750k,
From Delaware, USA
Does this mean that the bolts from the automatic flywheel won't work ?
Posted on: 2009/9/14 13:13
From Freo
without seeing them it's hard to tell,
other cars I've seen the flexplate bolts have a larger flatter head,
Posted on: 2009/9/14 14:23
'72 CB750k,
