electrical problems no spark - Do you know how the wiring should go from dissy to coil
From Perth WA Australia
Tried to get the engine started this weekend but no spark. I have gone from points (old engine)to electronic ignition (new engine old wiring loom )don't seem to be getting power to the coil.If you bypass the old balast resistor there is still no spark, any suggestions. This is killing me.
Posted on: 2009/9/14 14:03
Edited by ThomasSymes on 2009/9/16 11:36:19
Edited by ThomasSymes on 2009/9/16 11:43:28
Re: electrical problems no spark
From northern 'burbs adelaide
hmmm check fuses ... what coil are you using? and what dizzy is it?
Posted on: 2009/9/15 0:14
From perth airport
must be near finish :)
you running the pulsar dizzy or one of mal's ?
i have a spare coil n dizzy if ya wanna check that :)
Posted on: 2009/9/15 0:48
perth airport parking
Datsun 1200 ute A14
Re: electrical problems no spark - can someone tell me what model dissy this is
Fuses are good. Not sure what type of distributor it is, any suggestions, it has a blue and black wire running off it. I take it they should be pos and neg connections on the coil and if the coil has power to it, it should have spark at the plugs or the coil is not working. Not sure what the readings should be on the coil for a bench test.
Posted on: 2009/9/15 10:29
Edited by ThomasSymes on 2009/9/16 11:21:16
can someone tell me what model dissy this is. Obviously auto electrical stuff is not my bag
Posted on: 2009/9/16 11:23
From perth airport
looks like the n12/13 pulsur dizzy :)
Posted on: 2009/9/16 11:25
Datsun 1200 ute A14
Re: electrical problems no spark -Do you know how the wiring should go
Posted on: 2009/9/16 11:27
From ACT Aus
well it's a long shot but my coils weren't getting power and it was because my fuse box itself was stuffed.
Posted on: 2009/9/16 12:09
unfamilia wrote:
You have bump stops? Your soft
Re: electrical problems no spark - Do you know how the wiring should go from dissy to coil
From Adelaide, Australia
Do you have the correct coil for your ignition? Some need a seperate ignition module like a ecu for under the dash. I know the US model ignition systems do, yours seems to have the module in the distributor though.
Silly question but are all your earth straps on? Had that a few times when doing conversions etc. Theres the earth strap onto the timing cover and also from bellhousing to the brake line splitter.
Posted on: 2009/9/16 12:25
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
nothing from the bell housing
Posted on: 2009/9/16 12:30
