Wanted switch block 1000
From Perth
I need the switch block on a 1000 any model (except coupe)
Its the square looking thing where all the brake pipes go into from master cylinder to switch
Its on the firewall drivers side
Anyone got 1 or 2 ?
with switch if possible
Posted on: 2009/10/8 11:04
Re: Wanted switch block 1000
From Oberon NSW {Bathurst}
Are you talking about the brass block that divides the fulid out the wheels. 1 in 3 out. 1 for rear and 1 each for the fronts. If so I would still have a couple of them you can have. Just give me an addy.
Cheers,
Peter
Posted on: 2009/10/8 13:09
Cheers Peter.
nos4datsuns@bigpond.com
peter.maxsted@bigpond.com
0427 138 266
THIS YEARS RIDES & PROJECTS:
Tweaked 2009 AURION SV6(Daily)
I think I still have a proportioning valve that has a brake fail sensor (ex Volvo) I was going to fit this on the coupe once I did the rear disc conversion. You can have that aswell if you want.
Posted on: 2009/10/8 13:19
Cheers Peter.
0427 138 266
From Perth
Yes DF its the block that all the pipes go into and has the switch on the top
For 1000's
I'll PM you my address
Posted on: 2009/10/8 14:29
From Freo
you know where there's some dude...
Posted on: 2009/10/8 15:47
A15 PSI Project Motor
'72 CB750k,
From Perth
I'll take what I can get :)
Posted on: 2009/10/8 15:53
From Freo
I've heard that about you....
swing over dude..
Posted on: 2009/10/8 16:00
'72 CB750k,
