« 1 (2)
Re: ute tiedown hooks
From cold toast
so is it a bad idea?
what could ten to happen because of it?
Posted on: 2009/10/13 10:44
From Sydney, Australia
i don't really know, but thats what gives the walls their strength.
although plenty of people have done what you said.
just don't let people put pressure on it and it should be right i'd say.
Posted on: 2009/10/13 10:51
B110 sedan
Quite a regular
i wanted to do it on mine, but it will weakin the panel im pretty sure, so i took off the hooks
Posted on: 2009/10/13 10:52
From cold toast
yeah, ill do it anyways
it gets done heaps,
plenty of hiluxes have it done and they have much longer trays so yerrrrr
Posted on: 2009/10/13 11:12
From cranbourne, vic
hilux trays are different and much sronger, plus they have full a chassis..
most of the strength of the 1200 ute is in the inner qaurter, top rail and those puny little chassis rails..
Posted on: 2009/10/13 14:54
82 1200 ute - daily
89 R31 H.M.A.S. Skyliner - drifter
197? 1200 coupe - new drift project.
85 CMA81 nissan/ud 9.5ton banana back - tow pig for the drifter.
Do it! It looks great, and I get many compliments on the smooth rail.
Of course the downside is I can't tie anything down.
Posted on: 2009/10/13 16:40
From cold toast
yer, i could weld some hooks to the inside of the tray.
but i dont really mind.
and i want to put a hard top lid on it
so i wouldnt be able to tie anything into it.
cheers for the help
Posted on: 2009/10/14 0:50
From campbelltown (sydney) australia
im about to do the same thing completely remove it all and make an infill panel below the rear window so theres a square edge for a hardcover to meet.
can anyone who has actually done it tell me whether it is extremely weak or not? surely if its welded properly it should be ok, im going to put a folded 1.6mm angle along the whole edge and weld both sides too
Posted on: 2011/12/15 11:55
* caution, sunglasses must be worn to view my ca18det *
The rear panel is not weak, it is high-strength steel like the rest of the body. But it is sheet metal, so weld accordingly.
Posted on: 2011/12/15 17:59
« 1 (2)
