« 1 2 3 (4)
Re: traction rods EOI
Quite a regular
im keen for 4 sets when they are done, 3 coupe and one ute! :)
Posted on: 2009/10/22 11:16
From Newcastle
Ok time for an update.
The tube supplier has been pretty slow but hopefully I should have it this week.
Finally took a closer look at the ute setup today.
To attach the kits to the utes you will have to drill out the inner front spring mount hole, in the chassis rail, to accept a 12mm bolt. The stud on the utes has a step down from 12mm to 10mm at the chassis rail, there is no way around this unfortunately. If you were to remove the traction rods at a later stage you would just replace the bolt with a 12mm 90mm long grade 8 bolt so no real big issue.
Attached are a couple of photos of how it will sit on the ute.
This pic shows the ute mounting plate (original) and stud which holds the front spring eye
This pic shows the step down in the stud, the chassis rail will need to be drilled out to 12mm to accept a 12mm bolt right through. The stud is easily tapped out of the outer mount.
This pic shows the plate and bush mounted on the plate, note that the two outer bolts stop the plate from turning hence the change required in the design of the triangular plates.
Showing the triangular plate and bush on the outside of an original coupe/sedan/120y front spring hanger, it would be possible to do this will normal eyed springs (Reverse eyed springs will not work this way).
Another angle showing the above setup.
New coupe/sedan/120y hanger, triangular plate plus bush sandwiched next to the original spring hanger.
After some searching I have sourced some rod ends with a 3/4 UNF with a 5/8 rod eye, these are Teflon lined at a reasonable price. So am looking at going back to a 3/4 UNF L/R thread in each end of the rod (No plug reducing to 1/2 UNF thread).
Will keep you posted when the next round of parts arrives.
Bryan
Posted on: 2009/10/25 10:56
From Newcastle
OK update,
Have the rods now and am awaiting a Quote for the CNC lathe work.
The rods will have 7/8" hex flat machined into one end to allow on car adjustment.
Have made some test Delrin spacers and spring roller made so can check clearances this weekend.
I need to have the CNC lathe work done prior to getting all the parts zinc plated.
I have a bit of a compressed timeframe now as I am moving from QLD to NSW in three weeks.
Non the less I think the wait will be worth it.
Next update will be when the lathe work is completed.
Regards,
Bryan
Posted on: 2009/10/28 3:27
From Brisbane
Do you think you will have any ready before you head south?
Posted on: 2009/10/28 5:39
If you want more inches, stroke it
From brisbane. waking up the neighbours with the brap
i was hopeing you would have these sorted soon as im waiting for them to run my car on the track
Posted on: 2009/10/28 22:18
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
Not too shy to talk
Any progress mcgee on the traction rods.
Posted on: 2010/1/10 21:36
Quite a regular
From perth
are you still making these mate
Posted on: 2011/3/8 3:20
« 1 2 3 (4)
