Browsing this Thread:
1 Anonymous Users
Heater control valve - 1200 coupe |
From Seattle ,WA.
anyone know where to buy one of these, aftermarket , oem, whatever... or are there any from other models that retrofit to the 1200 heater box? say from a 210, Stanza, pulsar, any models?
Anyone ever rebuilt one, its got a C clip inside it & I might take it apart just to see if the seal can be replaced.
Ideas anyone - hell I'd buy one from AU or SA if they're available new oem. thanks, Evan
Posted on: 2009/10/25 16:36
Re: Heater control valve - 1200 coupe |
From Vancouver, Wa
Hey Evan, do you need another valve? Or are you looking to upgrade? I have another heater box assembly here. Dave
Posted on: 2009/10/25 19:40
1969 Datsun 1000 (B10) 1972 Datsun 1200 coupe (ADVAN) 1981 Datsun 210(B310) 4-door (sr20det) 1971 Datsun 1200 (sedan)
Registered Users Contentmaster Usermaster
I have a spare you can have. It is a good used one. B-pro sells new ones. Read this, it talks about alternatives: 1200 Tech: Heater Cock
Posted on: 2009/10/26 1:14
From Seattle ,WA.
Thanks guys, I have two but they both look like they've been leaking, you know, green hue/crust around the base. I cleaned one up & was thinking about pressure testing it under water to see if it leaks, just haven't done it yet.
I put the whole heater box back together with new foam & cleaned out & tested core so thats the last part I'll need. I know nissan says NLA but has anyone found new ones here ?
How bout you AU guys, can you buy a new one at a parts house over there for a coupe?
Dave, thanks for the offer, I appreciate the gasket you sent as well. I've got to heater boxes as well along with 2 used control valves.
Posted on: 2009/10/27 2:31
From Mie Japan
Hello.
Because there were several times questions, I purchased it from Nissan. This cook is for Ute.(27017-B8520) Bpro going to sell it in ebay if ready.
Japanese part database(fast system) was not able to see these below. •X2160-30600, X2161-30600 ASSY-VALVE WATER CONTROL B110 USA $18 USD
Cheers, Endo
Posted on: 2009/10/29 7:39
