bp motor info
the bp turbo from the familia will not mount up to the mx5 rwd gearbox, however, i am attempting to research if the bp crank and internals will bolt into the bp mx5 1.8 block... i think the crank fouls in the bearings, but the rods and pistons fit, and so do the manifolds
Posted on: 2003/10/6 10:21
Re: bp motor info
From Melbourne, Australia
sounds like big money
i really think the ca18det shines through by a mile
Posted on: 2003/10/6 10:23
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: bp motor info
personally, i like the 4age, to rev to 9000rpm... mmm nice and smooth.
the bp is a good motor but not in a datto. smooth and tourqey. i like its power dielivery better than the ca18..(poorly splet personal opinion, no flaming please).
Posted on: 2003/10/6 10:29
Re: bp motor info
i did like the 4age, but the n/a is too gutless and the s/c too heavy, then the 20valve is too expensive, but could be an option i guess
Posted on: 2003/10/6 10:33
1200 Coupe Rallycar
Re: bp motor info
in zoom, some guy put the 20 valve head on the s/c version.... naturally he blew the motor after 2 years of thrasing but what a thrashing it would have been.
i like the 20vale cause i like to rev, not short change to stay on the touque wave.
Best ride vas in a honda integra type r... 9000 rpm changes are the best... ohh the screaming that motor makes is fantastic, even if it only does 14 sec 1/4 miles.
Posted on: 2003/10/6 10:39
Re: bp motor info
yeah i heard of using 20v head on sc block and bolting up a turbo, but i mentioned it to toyomods and he says, at least to do that u would need to change pistons to accomodate extra valve, so even that is gonna end up pretty bloody pricey
i think the bp motor would be awesome, but in a gtr familia, as its an awesome car too
Posted on: 2003/10/6 10:42
1200 Coupe Rallycar
Re: bp motor info
From Auckland N.Z
Ive been told by a profesional engine builder that the 16v head is better than the 20v coz overall you can get larger inlet and exhorst and the 20v is more expencive.
Posted on: 2003/10/6 12:05
Re: bp motor info
Quite a regular
From Townsville
Ask me nicely and I can go out into my shed and take some photos and dimensions of a BP Turbo crank if you want. ;). I just sold my TX3 4WD after 5 years and found engine to be fairly strong to about 15psi and after that you get bent-rod-crontitus, hence why I have most of an engine sitting in my shed and the block(plus a blow gearbox) sitting at my parents farm. Ive got pistons, rods etc ready if you want some photos taken, just bear with me as Im a pretty busy fellow(part time Uni + full time work).
The head design of the BP Turbo is a bit of a mystery as well, Mazda has 4 flow restrictors in one of the intake ports on each cyclinder. Ive heard these are meant to aid in swirling the air into the chambers, also I hear it was to prevent to much low down torque as the Mazda 4WD boxes are made from glass. Defiently stick with a NA BP head if you get the chance.
Fingers crossed my new Mitsu wont have any problems that the TX3 did ;).
Posted on: 2003/10/7 2:55
Re: bp motor info
From Mandurah WA
Unlike the Mazda F2 Turbo that thing produces heaps of torque ! I would love one of those engines in a datto :)
Posted on: 2003/10/7 16:24
1984 Mazda 626 stocker..
Soon to be 32/36 weber powered
Re: bp motor info
yeah trannys are made of balsa wood when tourque is added and the slave cylinders rupture when you put a six puck paddle shift clutch into them on a lightened flywheel
thats why it would be good to bolt it all into a bp 1.8 na mx5 block and hook it up to thier non glass rwd gear box. deffinate possibility.
The bp has a reputation for strength in a hard enviornment, its the gboxes that always let them down.
Posted on: 2003/10/9 1:03
