lowering
From cold toast
hey guys, yes im back again with more lowering questions
will putting my load spring ontop of the leaf pack put me in any danger, or my parts?
thanks
Posted on: 2009/11/9 10:26
Re: lowering
put the next one up from the load spring,i wouldnt touch the load spring at all, leave it where it is. I actually moved the middle one.
Posted on: 2009/11/9 10:49
Re: lowering
From Melbourne, Aus
Has anyone got any photos of this being done?
I am assuming that it doesn't make the back any stiffer, just lowers it, is this correct?
I need to do something with the springs on the back of my coupe and i am not sure if I should go down this path or get the springs redone at a spring place to lower it and beef it up at the same time.
Posted on: 2009/11/9 23:35
Re: lowering
i put what i did in the wiki, now gone
check here
Posted on: 2009/11/9 23:37
Re: lowering
From cold toast
sorry not following?
Posted on: 2009/11/10 2:01
Re: lowering
This makes it stiffer. By moving the leafs to the stop, you create a bind.
But seems that is doesn't break anything...?
beutify leaf
All the wiki data is still there...if someone removed it, you can go to the history and get it back.
Posted on: 2009/11/10 2:15
Re: lowering
if your not following dont do it and risk injuring your self and others, take it some where to get done.
Posted on: 2009/11/10 3:02
Re: lowering
From Tamworth , NSW
^^^ ill second that. just take them to a springmaker or blacksmith and they will reset them lower properly all for about one and a half hundred.
Posted on: 2009/11/10 4:51
Re: lowering
From ACT Aus
sandbags?
Posted on: 2009/11/10 6:39
unfamilia wrote:
You have bump stops? Your soft
Re: lowering
From cold toast
i have had them reset 2.5 inch and they arent low enough for me
and on that pic that dd posted it has the load leaf on top
and yeah i do no what im doing, cus i have done it before to my mates car
i just didnt understand what you were saying
Posted on: 2009/11/10 9:21
