(1) 2 3 »
camber
From cold toast
hey guys,
just wondering if i was to run some positive camber on my ute,
would it screw my wheel bearings up, or make them wear quicker?
or is my ute light enough to have no real effect on it
thanks guys
Posted on: 2009/11/19 2:54
Re: camber
From Perth WA
why pos camber? usually neg camber for better turn in. Its something more for racing than road cars, it wont affect your wheel bearings but will half the tyre life.
Posted on: 2009/11/19 3:00
datsun 1000, Its not the size its how u use it.
Re: camber
I think positive camber would make it look pretty wierd.
Unless I have my positive's and negative's the wrong way round.
Posted on: 2009/11/19 3:37
Re: camber
you are in adelaide chris- more than your pos and negs would be the wrong way round....
Posted on: 2009/11/19 3:52
Re: camber
From northern 'burbs adelaide
now now ... its hot down here and thats the only reason we arent all there in the head lol
Posted on: 2009/11/19 4:02
Re: camber
The factory settings for almost all 1960s and 70s cars is positive camber.
From the Datsun 1200 service manual: 5' to 2°05'
Posted on: 2009/11/19 4:08
Re: camber
From Perth WA
would that be to allow for loading? 2-5 degrees is a lot.
Posted on: 2009/11/19 4:23
Re: camber
Not 2-5 degrees. 0 degrees 5' to 2 degrees 5'
Posted on: 2009/11/19 4:37
Re: camber
From ACT Aus
yeh neg camber helps heaps. i get free semi's so i run heaps on the road but if you have adjustables just wind it on for the track then run zero on the road. your tyres will actually last longer with camber if you're pushing it
Posted on: 2009/11/19 4:50
unfamilia wrote:
You have bump stops? Your soft
Re: camber
Yes:
* Your tires will last longer with camber
* But, cornering perf is better with negative camber
Posted on: 2009/11/19 5:05
(1) 2 3 »
