HELP !!! ANYONE WRECKING
From sydney
I'm after the brake lines in the engine bay for a B310 sunny, or does anyone know was size nut;s are used on the brake lines so i can i make my own.
Posted on: 2009/11/21 11:42
Re: HELP !!! ANYONE WRECKING
From Perth
10x1 metric
Same as almost every datto ever built after 1965
Posted on: 2009/11/21 17:21
From sydney
No worries, thanks dattoman =)
Still looking for someone wrecking a sunny tho.
Posted on: 2009/11/21 22:13
PROJECT:DATSUN sunny sedan CA18det
From sydney australia
What lines do you need exactly. I've got a Sunny panel van that I'm going to part out, so you can have them, just have to tell me which. Do you also want the proportioning valve they go into, which is that strange shaped thing down on the right hand inner guard? I know I've had problems with the brake lines before, as they seem to locktight them from the factory & you always seem to round off one or two of the brake nuts. If this is what has happened, any Enzed or Pirtek dealer should be able to supply new nuts, & you simply cut through the brake line as close to the flare as possible, slip the rounded off nut off, put the new on, then flare the pipe. There's usually enough slack in the pipes to make up for the tiny amount you cut off.
Or you can get new lines made up. I replaced the copper brake lines in my 1000 race car with steel by using welding wire to make a pattern. Just bend the wire into the shape you want, then take it along someone like Stewart Wilkins Rallying, or RaceBrakes at Wetherill Park & they should be able to supply new lines to suit. I had mine made by Arthur Jackson, who now works at SWR.
Posted on: 2009/11/25 10:18
From sydney
If you don't mind can i get the off your sunny p/van i'll come take them off i have the tools to do it.
I still have your number , i'll ring you on the weekend..
Thanks for all the ideas.....Cheers
Posted on: 2009/11/27 20:43
