Testing a stock tach-USA
Quite a regular
From California,USA
How can I test my stock tach (USA) without installing it?
Saw the wiring info. But has anyone done this with long leads back into the cab with an aftermarket installed tach working? I'd like to compare them side by side & functioning.
Posted on: 2009/11/29 6:55
Re: Testing a stock tach-USA
Open the hood. Disconnect the coil + wire, connect it to the tachometer "loop", then back to the coil. Black wire to ground. Yellow/red wire to battery +. Start the engine.
Posted on: 2009/11/29 7:49
Quite a regular
From California,USA
Any potential faulty readings by having two tachometers running @ the same time?
DD, has anyone told you that you're the best?
You are.
Good job man.
Thank you
Posted on: 2009/12/5 6:42
From Sri Lanka
Hi 70twodoorsedan
Yes Always He is
Thanks
Regards
sumith
Posted on: 2009/12/5 6:58
