Alternator conversions
Gday all.
Well the 35A alternator on the 120Y has become virtually useless since the sound system went in. Just looking for conversions to alternators with higher outputs, just wondering what others have used , pictures would be very helpful. I hav looked at the tech wiki article and couldnt really find what i was looking for
Posted on: 2009/12/7 11:56
Re: Alternator conversions
From South Africa, Bloemfontein
Is yours also sitting there in the bottom underneath the water pipe that goes into the block?
I also want to upgrade mine as it is a $hity make, but I don't know what will fit without huge mods.
Posted on: 2009/12/7 12:04
1977 Datsun 1200GX
im currently using a 50amp xf falcon one, just needed to mod the bottom mounts by removing some meat from the arms to fit the 1200 mounts to the block.
internal reg alternaor, works well. pully slightly out of alignment, no biggie though
Posted on: 2009/12/7 13:11
sorry guys i should have mentioned, mines mounted up the top of the engine
Posted on: 2009/12/7 19:50
I ran a Sigma alternator for a about 10 years... internally regulated, bolts up to the standard 120y mount on the block. I'm not sure how many amps it put out though or exactly which sigma it was from. It worked fine.
VN Commodore alternators are a pretty common conversion on a lot of modded cars - you need to swap the pulley for a v-belt type one (the Commodores have a serpentine belt). They output 105 amps. Not sure how close they'd be to fitting a 120y though.
Posted on: 2009/12/7 22:36
this sigma alternator is starting to sound the goods... u wouldnt have a picture of it, would u?
Posted on: 2009/12/8 7:04
Unfortunately no, but I sold my coupe to Gylezy on here, so if you PM him he might be able to give you more info about it - like a part number or something.
Posted on: 2009/12/8 9:14
From SA
gday...
i could do that, no worries at all :)....
ill have the pic here by tomorrow night, (car isnt here)
and a part number too buddy
cheers
Dan
Posted on: 2009/12/8 9:57
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
THANKS.
Muchly appreciated!!!
Posted on: 2009/12/8 10:36
