To Team_Dat Street / race, almost a contradiction in terms, but i will proffer my solicited opinion.
I will assume that you will be seeing a lot more street duty than race, & for this reason i tend to be a bit more conservative than some others. An engine like this is in my view, best "developed" rather than building an all out banzai screamer first up.
If i read it right, you are using an A14, & this is a good choice, so i would be looking for an A14 / A15 oval port head with the smallest combustion chamber. These are basicly GX heads with bigger valves & bigger combustion chambers. They are easier to find & lower in price. My experience has been with A12's so hopefully someone here can identify which head had the best combination of port size & combustion chamber volume. With any luck, you may already have the best core head on your engine. I will be rebuilding my GX head with A14 valves & hard seats so i can run on LFG. [lead free gasoline] You could safely mill some metal from it, but i don't know if i would go to 100 thou. 60 thou strikes me as leaving a stronger deck, keeping in mind that these heads are made of alloy & not iron.
I like the suggestion offered by "sunny" of the single DCOE Webber, but for gods sake, if you use it, or a single DelOrto, factor in the cost of a propper dyno tune. That's the true beauty of these carbs. They are so incredibly tuneable, but they need to be tuned by a pro on a dyno to get them right. Once done, you should not need to touch it again, & you will LOVE it.
Cam. The best grind for this engine is likely to be the one that the reputable cam grinder that you will be using, recomends. He will need to know a bit about the car & the engine & he should make his recomendation knowing that if he screws it up, you will tell everyone, & thats bad for business. If he gets it right, you will tell everyone, & thats good for business. I have used Bert Jones in Parramatta with great success, but it was a long time ago & i do not know if they are still in business.
Extractors are always a good idea. I prefer the GX manifold myself, but extractors are easier to find & work well.
Balance the whole rotating / reciprocating assembly.
This is a good start. I suspect that head work will not yeild a great improvement in performance at this level of tune, but can be considered if you decide to get serious about racing.
See if you can find a 1200 flywheel & have a little shaved from it prior to balancing.They are lighter than the A14 one, but are dimentionally interchangeable. I use a 1000 flywheel that has had a cut across the face down to the bottom of the groove that surrounded the original tiny clutch disc, then redrilled for the later clutch . These are the lightest of the "A" series flywheels, but don't get carried away with weight reduction.
This should provide you with a strong street engine with the capacity to give you a fright on the track, & it will have the room for further development in the head & carb area without tearing the whole engine down. If you are going to bore it, i suggest going to the second oversize. It is a full 1mm oversize while leaving room for one more bore should you score a cylinder.
This should also be a reasonably affordable engine that should start easily, run well & live long. The unported head & single carb tie in with your comment that you need to work within a budget & the need to maximise your performance return per dollar. I think that the suggestions above will go a long way towards achieving that, but i would dearly love to see what Feral has to say as he has a much greater depth of experience. Well, thats my two bobs worth Conservative Chris
Posted on: 2003/10/21 14:48
