How much does a 1.5mm head gasket get compressed to?
Webmaster
From Lisbon - Portugal
Webmaster
Hi,
I'm doing some compression calculations and I'm missing this variable, any one knows this for the std tightening torque?
Thanks
daniel
Posted on: 2010/1/3 22:57
Keep them alive and sideways!
Re: How much does a 1.5mm head gasket get compressed to?
I believe it is 1.5mm after torquing. The GX gasket is 0.8mm very thin.
Posted on: 2010/1/3 23:46
Webmaster
Webmaster
Hi,
I've bought the gasket from ebay, and it mesures 1.5mm. It will not compress any thing after I torque it?
Thanks.
daniel
Posted on: 2010/1/3 23:51
If it is 1.5mm to start with, I do not know.
Anyone know?
Posted on: 2010/1/4 0:40
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
Will the gasket manufacturer provide tech info?
Posted on: 2010/1/4 16:42
From Coondle, WA Australia
That would be info that the manufacturer would need to provide since depending on the materials that the gasket is made from, will change the final height.
ie if the gasket is very hard/dense then very little compression would occur before the max torque setting is reached.
a very soft gasket will compressess more before the max torque setting is reached.
Posted on: 2010/1/4 16:48
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From Wellington
Hiya, I was trying to work this out the other day. Is this a metal shim? if so then I came up with 8.35/ 1 c/r for an a15 with 77mm bore and standard h89 head.
Posted on: 2010/1/4 21:26
From Wellington
Just relised I was off topic, sorry no idea
Posted on: 2010/1/4 21:49
