points distance
From cold toast
hey just wondering what the distance for the points is on an a12,
thanks
Posted on: 2010/1/5 1:37
Re: points distance
From south coast nsw
i think its .45mm u best check that but
Posted on: 2010/1/5 2:12
Re: points distance
New points can be gap-set to 0.018-0.021 inch (0.45-0.55 mm).
Used points must not use these measurements. Use a dwell meter and set to 49-55 degrees dwell.
Posted on: 2010/1/5 2:30
Re: points distance
From cold toast
wicked
thanks for your help guys
may i ask why someone would put used points into there car?
Posted on: 2010/1/5 2:42
Re: points distance
Why? Consider that you are in the bush, far from any parts store. Your points burn out. But, in the boot is an old set. It will enable you to proceed.
But more commonly, one may wish to adjust the points after six months or so. Using a thickness gauge will result in inaccurate setting due to the natural pitting that occurs. Instead, a dwell-meter will give an accurate measurement with both new and old contact points.
Posted on: 2010/1/5 4:43
Re: points distance
If I remember rightly, the book says, ..... reset points gap at 5,000 miles & replace with new at 10,000 miles.
This was the industry standard for decades, so, fit new points, drive for 5,000 miles, then reset your [now] used points & timing, then drive another 5,000 miles & replace with new again.
As for me, ... well screw that, I fitted a Pertronix electronic conversion & have NEVER looked back.
Posted on: 2010/1/5 11:32
Love your Datsun.
Treat it well.
Re: points distance
From cold toast
yeah whats electronic ignition worth and how do i get my hands on it also whats it like to install the parts, what do i do with the dizzy also.
Posted on: 2010/1/6 2:10
Re: points distance
Well, I guess that you could always go to your favorite search engine & type in Pertronix
Then, you could select from the list & go to Pertronix Australia & NZ.
From there you could navigate your way around to learn all about it.
You might even contact them to ask where your nearest retailer is located.
Now that shouldn't be too hard & you will quickly become an expert on the subject.
Have a look at some of the other sites thrown up by your search engine, just for fun.
Posted on: 2010/1/6 3:31
Love your Datsun.
Treat it well.
Re: points distance
From cold toast
sweet cheers
Posted on: 2010/1/6 4:08
Re: points distance
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
Just keep a matchbook in the glove box. When the points quit out on the road you can sand oxide off the contacts with the striker and set the gap with the matchbook cover.
Posted on: 2010/1/7 3:18
