problem..
From sutho shire
coming home last nght i was hammering along a backroad.. as i do..
all of a sudden my lights shut of and car stoped.. Noooo!
i had absoloutly no power what so ever although i roll started it after about 10minutes..
and got home?
i have checked battery, fuses , any loose wires 2 alternator and starter motor..
i still have no power at all.. 2day troughout the whole car.. new alternator?
Posted on: 2003/10/25 3:52
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: problem..
Not too shy to talk
From Dallas, Texas (White Rock Lake)
I had the same problem once. Try the fusible link first then the fuse panel. I noticed my fuses got "corroded" over time and replacement fixed that problem. If the fusible link comes loose on the + side of the battery then everything goes dead and stays that way. Hope this helps. more than a pint at this moment and feeling no pain.
Posted on: 2003/10/25 5:58
Re: problem..
That happened to me as well, and it was the fusible link. In my case, the link didn't burn out, but the spade connectors were corroded and loose.
Posted on: 2003/10/25 6:42
Re: problem..
this also has happened yto me, ended up being that crappy plastic connector for the ignition switch, when i hit a bump, it would cut out all powr cuse the terminals would not connect. Fixed it with spade connectors.
Posted on: 2003/10/25 23:39
Re: problem..
From Melbourne, Australia
circuit testers/ light testers are brilliant!
try one start from the battery and work along
Posted on: 2003/10/26 9:57
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
