i dont think anyone has put together a simple offset guide for 1200... but for good reason
to fit 16's you have no hope on the standard 1200 front suspension (specifically struts)
the lower spring cup is too close to the ground to fit wide large wheels in the wheel wells
typically people fit stanza struts to get the clearance for these sorts of wheels, but there is a few other options with struts as well
i have 6" wide 15's with offset of +38 but i require small spacers (3-5mm) with 195 tyres so that they dont hit the strut
with 6.5" i think you are really pushing it as with the wheel as close as safe to the strut your still going to need to strectch the guards out to cover the tyres (assuming 195-205)
there is offset calculators on the web that help
LINKputting the numbers in my 6" vs your 6.5 me with offset of 42(including spacer) vs your 40
it says you will have 4mm less clearance on inside, so you will need spacer as well, but also extend out an extra 8mm.
the kicker is.... i have 2 inch flares and am already half filling those out
in adiition to rolling and pumping your guards you will need to take a hammer to the foot well to get extra clearance at the back and bend the front of the gaurd out of the way to be able to steer the car still
sounds like fun?
everyone with big wheels is doing it so its not that big of a deal but thats what you need to do (hope the paints not too nice cause that will be cracked in the process)
[EDIT] whoops just realised i arsed that up, the spacer in effect reduces the offset... so i realistically have say 35mm meaning your wheels have 11mm less clearance on inside and extend out only 1mm (meaning you would need roughly 15mm spacer and 2in flares)
