(1) 2 3 »
Maddat booster set up.. question why it wont work
From Adelaide
hey guys,
the booster i got on my car is a maddat one, the hose has vaccum what connects to the booster,
but i got a hard pedal all the time... even when the car is started..
what could it be? #OOPS#ty booster? can u open them up?
Posted on: 2010/1/23 13:50
Re: Maddat booster set up.. question why it wont work
From hastings,vic
u can open them up( not suggested )
can u here hissing coming from the booster when u apply brakes?
is there any difference in peddle hardness going not going?
Posted on: 2010/1/23 14:02
taking up room at home
hzj75 cruzer tray(for sale)
and allways changing
From Adelaide
yeh when i pump it i can hear a hissssss.. but we didnt find were it wsa comming from.. check the hose an that..
yep pedal is hard 24/7
Posted on: 2010/1/23 14:07
From Adelaide
i dont have a vac check valve... could that be the problem?
Posted on: 2010/1/23 14:16
From hastings,vic
hissing is coming out of booster were rod comes out
that go's to pedel,its fvked
Posted on: 2010/1/23 14:18
From Adelaide
can they be fixed? if so how much you reckon?
so the rod that connects to my pedal its #OOPS#'d on that side or the master cyclinder side?
the hisss you can hear is a SSHHH sounds when u pump the pedal
Posted on: 2010/1/23 14:24
From hastings,vic
can be fixed
hissing coming from pedal side
hissing is vacume leaking in the booster when u apply brakes
booster vents into cabin not engine bay
try your local parts supplyer they should be able to get it rebuilt
Posted on: 2010/1/23 14:30
From Adelaide
Ben, i think you have #OOPS#ed the booster by not nunning a check valve, the valve holds vacume when your engine is at high revs, and also stops boost pressure entering the booster. By not running one the boost pressure has eather popped your diaphragm or the seal has slipped.
Bring it up one day and i'll see what it is.
Posted on: 2010/1/23 21:50
From Adelaide
Scott i would of thought when you buy products if another product was needed you would of been told or the part would also been sold with it..
yeh i might just go to u pull it an get a valve an see if it works
Posted on: 2010/1/24 0:06
From Perth
You will hear a hissing noise when the booster is applied anyway
Check the front seal of the booster where it goes to the master... Dastun boosters are notorious for ripping the seal
As for check valve... yes make sure you fit one
When you bought it maybe they assumed you already had one on the car in the line
Posted on: 2010/1/24 3:13
(1) 2 3 »
