WTB a12 early front dizzie block and crank.
As per title has to be the early engine.
Can be damaged at the rear as it will be
cut up for a6 project.
Posted on: 2010/1/27 3:50
Re: WTB a12 early front dizzie block and crank.
From Tamworth , NSW
sounds interesting D.
are you going along the same lines as that L6 with the chopped up KA heads on it?
Posted on: 2010/1/27 5:45
AY6!
Posted on: 2010/1/27 6:26
From Bendigo, Victoria
Got a few of them here in Bendigo. PM me if interested.
Posted on: 2010/1/27 7:11
Bendigo where is that? :)
Pm sent
Its a toss up between using a suzuki 3 cylinder or a datsun
but how could I use a suzuki when ill have to mod a bellhousing
for the auto anyway.
Its a scary project so will let you guys know whats happening
when its started.
Posted on: 2010/2/1 13:12
dontae the capacino 3cyl turo and use the slick gear box too. speed limited in stock form but yum yum yum in not so stock form.
Posted on: 2010/2/1 22:45
An a6 with full 83mm bores using full sleeves and 73mm offset crank
using suzuki gti conrods thats 790cc in an a12 block that passes for a
600cc engine for a P plater motorbike. Nice torque and 45-50hp depending
on tune.
Posted on: 2010/2/2 2:02
