A14 overheating problems
From mandurah
hey everyone i have a had a problrm with my A14 as it keeps overheating
is there a radiator that i can use to stop it for over heating ?
Posted on: 2010/2/6 6:14
Re: A14 overheating problems
Yes, the stock Datsun 1200 radiator, if in good condition, is good enough for A14.
Is your radiator having good fins?
Posted on: 2010/2/6 7:16
From mandurah
no the standard radiator is stuffed ,is there a radiator that will replace the standard item(hyundia?)
Posted on: 2010/2/6 16:13
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
is there a radiator that will replace the standard item?
Yes, the radiator from another 1200. Or better yet, the radiator from an A14-powered B310.
If you must fit a non-Nissan item, there are hundreds of radiators small enough to fit into a 1200.
See datsun1200 Tech: radiator
Posted on: 2010/2/6 19:03
From perth
use the one out of the coupe that came with the engine it was ok before
could be ign timing too jess which would also explain your other prob
Posted on: 2010/2/7 6:03
From mandurah
ok ill try that dazza cos i am using the utes radiator and it isnt too flash !
Posted on: 2010/2/7 6:11
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Always go back to basics.
Is the radiator serviceable? No? Then replace it with one that is, or get the faulty unit fixed by a competent radiator repair shop.
My personal preference is to go for a heavy duty core & triple row if possible.
But that costs money I hear so many cry.
Well so does a cooked engine, & the radiator still needs to be fixed once the engine is repaired/replaced.
I put a new core in my 1200 coupe several years back & with the aid of a coolant filter [cheesecloth condom type] the radiator has remained clean & the temp has remained in the zone despite a recent 'devastating' heatwave in Victoria & a faulty thermostat.
Yes, I drove all day through central Victoria & into NSW on the Monday of record temperatures. Never missed a beat.
The original 1200 radiator, particularly with a heavy duty core, is a surprisingly efficient unit.
Posted on: 2010/2/7 9:36
Love your Datsun.
Treat it well.
