ANYONE USED AN S12 GAZZELLE GEARBOX
From sydney
Has anyone used a gazzelle gearbox behind there ca18 powered 1200.Do they fit in the tunnel.And do they last
cheers
Posted on: 2010/2/9 3:52
Re: ANYONE USED AN S12 GAZZELLE GEARBOX
1200 tunnel from Automatic 1200 will fit any big transmission. It is designed for the 71-series.
Nissan Gazelle is just a different market name for the Nissan S12 model series. Which is called Silvia in Japan, and 200SX in north america.
Posted on: 2010/2/9 4:09
From Melbourne, Australia
i have one but bought a stumpy when i saw one for sale, the gazelle box is definately a fair bit longer
would fit though
Posted on: 2010/2/9 4:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From sydney
so the gazzelle box is a fair bit longer is the shifter further back than the stumpy also have you seen a gazzelle box next to ca box by any chance
thanks
Posted on: 2010/2/9 5:07
nah only gazzelle next to stumpy, went with stumpy because the shifter was closer to engine, came out in the middle of the auto shift hole
the gazelle box shifter was at least 4inches possibly 6 behind that (cant remember measurement but significant)
Posted on: 2010/2/9 5:23
1200 Coupe Rallycar
From sydney
If thats the case i guess i should just use an s13 box then aye
Posted on: 2010/2/9 5:51
From Geelong, Vic
or you could use an r31 box, they are just as strong as the s13 box but are about 2 inches shorter
Posted on: 2010/2/9 11:14
From sydney
Do you know whats involed in the r31 box conversion
thanks dude
Posted on: 2010/2/9 11:19
From Geelong, Vic
just bolt a CA bellhousing onto it, conversion done
Posted on: 2010/2/9 11:27
R31 was also available with CA18 or CA20, so gearbox may already have the correct bellhousing. Especiall if you get an import gearbox.
Posted on: 2010/2/10 3:10
