(1) 2 3 4 »
Copper Head gaskets who has used them and how to use them?
From South-Africa,Pretoria
Anyone made use of a Copper gasket of 2mm plus to help compression ratio on a over skimmed gx head? Im wondering do they work better, how to seal them properly without o-rings ect.
Thanks
Posted on: 2010/2/21 8:15
1993 Nissan Bakkie - Rebuilding A15
www.spitronics.co.za
Keep it OldSchool, keep it Datsun
Some can afford the legends, other try to revive them.
Re: Copper Head gaskets who has used them and how to use them?
From Perth WA AUS
I have a copper head gasket on my motor, its only about 1mm thick though.
It seems to be sealed with some kind of white looking sealant. The motor has been thrashed long and hard, no problems.
Posted on: 2010/2/21 8:38
Datsun 1200 2Dr sedan.
good to know, wonder if it was just normal silicone?
Posted on: 2010/2/21 9:35
From Perth WA AUS
Yes it seems to be some kind of silicone.
jpg  Head gasket.JPG (45.30 KB)
9665_4b81118c3b708.jpg 816X612 px
Posted on: 2010/2/21 10:57
levey so you didnt put it on i gather, but you say it works fine, and you dont use o-rings?
Thanks for the pic
Posted on: 2010/2/21 11:16
Not too shy to talk
From Canberra
I have used copper head gaskets in my older cars and have used copper spray.
This stuff is hard to get and the last head gasket replacement I used Hylomar
Spray (I hope spelled that correctly) Its a blue tacky spray and has done the
job well.
Posted on: 2010/2/21 13:37
1200 Coupe x3
Peugeot 403 panelvan
From Cape Town South Africa
Clive as a matter of safty you can use any good metal to metal sealant, coper tack, yamaha bond, hylomar and so on. But there is nothing wrong with a coper gasket.
Posted on: 2010/2/22 6:04
Racing started the day the 2nd car was built!
From South Africa, Bloemfontein
Why do you want to use a copper one?
My mechanic friend told me you can order a custom thickness one from Payen. He once installed one on a over skimmed BMW engine of 3mm thick. No problems yet.
Posted on: 2010/2/22 6:53
1977 Datsun 1200GX
From Perth WA AUS
No Clive I didn't fit it so I know nothing, Sidedraught might know cause the motor originally came from him.
Posted on: 2010/2/22 6:56
Thanx guys, i know a guy who makes gaskets from either copper or ali. Need a 2mm. Defnately going 2 give it a try.
Posted on: 2010/2/22 10:00
(1) 2 3 4 »
