« 1 (2)
Re: Short A14 twin carb manifold???????
From Townsville, Qld
another idea could be to scollop that area of the firewall but that seems like the same amount of effort or even more then the other one.
Posted on: 2010/2/25 9:33
From Adelaide, Australia
Can you angle and lower the motor slightly with a different engine mount/s, I have no idea if that would be ok with a FWD datsun? I notice your not running insulators between the manifold and the carbs either... vibrations will cause fuel to froth and crack the ears on either carbs or manifold.
Posted on: 2010/2/25 10:08
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
From Tasmania
Maybe I should just go to EFI!
Posted on: 2010/2/25 10:29
Proud member of " The Tasmanian Datsun Owners Group"
Can't rotate the motor a little bit? Those insulators are only about $30 a pair, much cheaper than efi.
Posted on: 2010/2/25 11:02
IPRA Build
From Tasmania
Dont worry I wont be going efi to many wires for me. Yeah I will look into getting some insulators. I will get to have a bit more of a play with the car today and see what I can do with the engine and if I can reposition it.
Posted on: 2010/2/25 21:09
« 1 (2)
