tailgate, how u did it? and has anyone used those aftermarket ones?
From the central coast, nsw
hey guys just wondering if u guys got some pics on tailgate mods, and has anyone had a drama with those #OOPS# aftermarket ones that sit way to high on the lip. thanks guys
Posted on: 2010/3/4 11:32
Re: tailgate, how u did it? and has anyone used those aftermarket ones?
From Nations Capital, Australia
I'd like to know too. Thanks for asking Waz.
Posted on: 2010/3/4 11:45
search bar....
Posted on: 2010/3/4 12:18
Search finds nothing.
Instead go to the wiki, and use the Go To box at the bottom of the page. Put in Tailgate. There are pictures of custom tailgate modifications
Posted on: 2010/3/4 20:40
From Geelong
i had to pack up one corner underneath the hinge with bog, and peter a thin layer of bog along the top of the beaver panel to keep a uniform gap. sh*ittest job ever but i got it close. unfortunately the aftermarket ones have a top lip that leans forward, rather that flat along the top of the lip. hmmm fun and games haha
Posted on: 2010/3/5 0:14
From Geelong
but if the tailgate sits too high, then hmmmmm probably not a lot you can do haha
Posted on: 2010/3/5 0:16
From pooraka,,adelaide
shave it =)
weld shut= sexy
Posted on: 2010/3/5 1:14
620 ute -sr20det full irs
vanette-a15 turb
260c- daily
1000 4dr- a15
1000 4dr- project to be sr20
garage 910
From Brisbane, Queensland
I found just grind the top lip off using a 1mm cut off disc, then trim the top lip so it will sit at the same height as original, then just use a mig with .6mm wire to weld along the inside and grind back. Use the .6 wire that way there is not alot of heat being put into anything that will make it bend or warp...
Posted on: 2010/3/5 3:47
Until Morale improves the beatings will continue
From Sydney, Australia
we're putting a hardcover on our ute, so we are just going to run a strip of rubber along the side lips to make up the difference.
easy fix for us, but without a hardcover id just shave the lip, cos its only the lip on the tailgate that is taller, not the actual tailgate body.
Posted on: 2010/3/5 6:22
B110 sedan
From Geelong
yeah i was considering doing the same, its only that rail that needs drilling off. wouldn't it affect the strength a little bit tho?
Posted on: 2010/3/5 6:52
