Browsing this Thread:
1 Anonymous Users
Re: Who runs a high Compression-Ratio and what fuel do you use? |
Registered Users Contentmaster Usermaster
Forget E85 or any E/petrol blend -- ethanol makes less power than gasoline.
Go with the 110 Avgas, which is petrol (gasoline) and is good for 14:1 compression.
Posted on: 2010/3/4 20:38
shame its not readily available any more in australia- unless your part of a small airport or some sporting applications.
basically you cant get it at the service stations
Posted on: 2010/3/4 20:45
chris why not put an a15 oval port head on there to drop compression a little, if you could get it to around 11.5 or so you would be ok.
if honduhs and celica's can runn 11 crs, dont see why you couldnt with good tuning. but when you gt it back to png avgas might be more available ;)
Posted on: 2010/3/4 20:47
From gold coast QLD.
Chris,pull it back to 10.5,we've had nothing but grief in recent times with comps any higher than this given the nanny goat piss(see petrol)available these days.The 98 available from BP will give you the right bang for your buck,and forget octane booster(long term)too costly and next to worthless unless your throwing litres at it at a time....Avgas...hard to get,expensive,not available by pump unless your very friendly with your local airport authority and furthermore we are being weened off it at motor sport events more and more as the years go by.In time it will be banned for motor sport. KISS 10.5 will be more than enough but i would DEFINATLY put it on a chassis dyno. Research an operator by phone(may take a while)and if he's any good he will give you a basic jet/choke set up over the phone prior to taking it to his dyno once you explain what the engine measurements and goodies are.
Posted on: 2010/3/4 20:58
I'm going with E85 and I believe it is sold at a depot near me. Have to make a few phone calls first to confirm it's availability.
It is cheaper or as cheap as standard fuel, produces a little less power which I probably would have lost in the advanced spark anyway running the BP Ultimate [98-102 RON].
I am convinced it will not affect the current fuel system components and I'm convinced that with the higher compression, the power results may not be as [comparatively] low as expected.
AvGas still burns very hot and I'm not sure on the specifics of the lead contents of the fuel so it sounds like a fairly aggressive fuel to me. I know the OG Speed Shop here in Adelaide sells it but it's a fair drive just to fuel up. I'll have to find out more about it first so I'll start with E85 and perhaps dilute it even further to achieve a higher gasoline - ethanol ratio.
To me E85 sounds like a rather tame, high-octane, cool burning fuel, and I'm pretty sure that's what I'd like to run.
Does anyone run AvGas in their street car? Costs? Whats with the lead content too?
EDIT:
Hey Bert,
That certainly is how things are looking but I don't have the gear to reduce the comp ratio at the moment so finding an oval port head means I'll need a new manifold to suit[ current manifold is port matched]. So the costs to change aren't really within my grasp.
Have you hd much to do with this ethanol blend stuff?
Posted on: 2010/3/4 21:02
From Ballarat Victoria
Yes, Ethenol and methanol make less power(pound for pound)than petrol.
BUT, you have to burn a lot more of it to get the same Lambda readings which brings the BTU`s(heat energy)per combustion cycle close to petrol.
The other thing is the higher octane rating, This allows timing to be optimally set on higher comp and higher boosted engines and allows for boost to be safely increased. This allows for higher HP than pump petrol.
If an engine doesn`t require the extra octane, ie a standard A12. little or no power may be gained with the use of ethenol. The engine would still have to be tuned to find this out. If someone was to drive their car into a petrol station and just fill their car with an ethonol blend there would be a big power drop and the higher the ethenal in the blend the higher the HP drop.
So, The engine MUST be tuned for it. And to get the most from it the compression or boost should be raised from standard.
Posted on: 2010/3/4 21:36
Edited by sikyne on 2010/3/4 21:51:03
VIC DYNO HIRE
Anything over 11.5 you should use 100+ RON. I had a DC2 Type R and i couldnt run it on anything less than 98 and it was 11.2 C/R from memory. Also, a mate has a built 250 chev in his HZ ute that had a 12.4 C/R and not even 98 could help it, if u floored it you could here it pinging like crazy. Im not a fan over octane boosters but they may be necessary. I remember reading something about mixing methanol and normal fuel in the latest motor magazine and they said the perfect mix was 60% fuel to 40% methanol. The Meth was damn cheaper than the fuel and it still worked out to be cheaper...
Hope i helped :)
** Av-Gas is illegal to use in cars ont he street obviously, and if your vavles arent up to scratch you WILL burn the valves and seats out. Getting it isnt hard but it is nearly 3 times the price of normal fuel.
I heard SA moved away from the E85 blend? Interesting...
Posted on: 2010/3/5 21:00
The new F458 has 12.5 compression ratio and runs on Premium pump fuel. But then it is an advanced, brand new combustion chamber design...
Posted on: 2010/3/5 22:39
Hey Fenix,
As far as I'm concerned they're considering bringing it in on a larger scale. AT the moment it is sold at independent service stations and I believe some larger farmers are planning on producing it in bigger quantities, so they must know something.
AvGas simply isn't on the agenda. It is far too aggressive for my liking and I am not prepared to pay the risks or the prices.
The methanol blend is interesting but I really need a fuel available from the pump as I don't have the means to store any fuel at my residence.
Sikyne nailed it on the head. E85 does not have the power as gasoline does. But by increasing the stock compression ratio your differences in power compared to a gasoline 11:1 engine would be fairly surprising I suspect.
Personally I am expecting good results from this fuel. AT the moment I am double-checking my compression ratio just to be ABSOLUTELY sure that I have it right and then I'll move to basic jetting.
EDIT: Thanks dd, I wouldn't expect Ferrari and Datsun to come together very often! I could always try water injection to cool the high-comp charge but I really don't have the knowledge.
Posted on: 2010/3/5 22:56
From Invercargill, new zealand
AvGas is gasoline which has been developed for piston engine aircraft. there are a few types, 100LL which is essentially 100 octane low lead, then theres 110/130 which is 110 octane rating in a lean mixture configuration and 130 octane in a rich mixture equivelent. Avgas has a certain glycol content to prevent freezing at high altitudes (Avgas is used up to about 13000 ft AMSL which in standard atmosphere conditions is -11°C outside temp)
All avgas has lead in it to help boost the octane rating and keep combustion temperatures down. It also acts as a good upper cylinder lubricant and keeps valve seats happy. It is not good for oxygen sensors or catalytic converters if you have them fitted.
Many people believe that high octane rating means more power and harder on the engine but this is not true, it just equates to a more controlled burn and thats the main factor. Sure, there are other effects of higher octane but the main is higher octane = less prone to detonation which is caused by too lean or too high compression ratio.
Avgas shouldnt be used on the road because it doesnt have any road tax attached to it and you are in the crap if you get caught. Your car should also be tuned to take advantage of it and i think this involves a little leaning and more ignition advance than what you would use for pump gas.
Posted on: 2010/3/6 1:14
